95 accord lx timing belt and belt balancer changing help>
Old Dec 6, 2004 | 03:08 PM
Integacivic's Avatar
Default 95 accord lx timing belt and belt balancer changing help>
I have a 95 accord lx 4 cyc. I want to change the timing belt and the belt balancer, I have both the belts. Besides removing everything like protective panels, and the engine mount. Then the crank pulley, all I have to do is set the balancer belt to TDC and the cam pulleys to TDC and mark the belts, pull off carefully and replace. Should I worry about anything else, this is my first time working on this car, accords are kinda diffrent from my teg. Any info would help, thanks.
Old Dec 6, 2004 | 11:30 PM
sinister2c's Avatar
Default Re: 95 accord lx timing belt and belt balancer changing help> (Integacivic)
You will need to make sure the rear balancer shaft in the right position...theres is a 12mm bolt on the back of the engine behind the water pump that you must remove and insert a screw driver into to hold it in the right position.
If you havent already gotten a balancer seal retaining clip get one.
Also might want to replace balancer seal and main oil seal and water pump and cam seal.
Crazy3rdgen
Dec 22, 2010 12:28 PM
sobey
Nov 9, 2008 09:55 AM
rickashay
Oct 17, 2008 04:14 PM
NewfieAccordEXR
Apr 29, 2006 11:26 AM
