Help w/ Install of Si front sway?
Old Jan 1, 2002 | 08:39 PM
r0b1n's Avatar
Default Help w/ Install of Si front sway?
hi... i got an Si stock front strut bar and i wanted to install it onto my 2000 civic sedan. the place where its supposed to be mounted is filled with im guessing a metal plate under the two holes where there are supposed to be screws? can any1 help me with the installation of this into my car? or does anybody know if itll even fit? ilookd my frnd's civic ex and his two holes where the front sway would fit are also plugged. help please!
Old Jan 1, 2002 | 10:15 PM
BagelW's Avatar
Default Re: Help w/ Install of Si front sway? (r0b1n)
It will fit. I had a stock 2000 Si front sway bar on my 96 Sedan. I guess I haven't seen what the 2000 sedans look like but I had to drill holes for the screws to go through. Is the plate you're talking about underneath in the wheel well?
Old Jan 2, 2002 | 06:15 PM
r0b1n's Avatar
Default Re: Help w/ Install of Si front sway? (bagelw)
o dang so i gotta drill 4 holes huh... wut size bolt? where does the sway attach to? just the body? if its just the body and not the strut will that even do me any good or give me an benefit of having it?
Old Jan 2, 2002 | 06:34 PM
LRCivicEX's Avatar
New User
those places you're talkin about where the brace mounts on the Si's thats right, you have to step drill the holes and just get four bolts...simple really...
Old Jan 2, 2002 | 06:36 PM
TurboSedan's Avatar
New User
Default Re: Help w/ Install of Si front sway? (LRCivicEX)
Drill, screw......what could be easier?
Old Jan 2, 2002 | 09:33 PM
Gump's Avatar
Default Re: Help w/ Install of Si front sway? (97CivicFerio)
in your title its "Help w/ Install of Si front sway?" but then you say front strut bar
a_benito86
Suspension & Brakes
May 8, 2017 11:46 PM
xeejay
Dec 17, 2014 11:10 AM
RetroGamer
33
Aug 19, 2011 03:50 PM
pr0m3
Suspension & Brakes
Jan 23, 2005 08:12 PM
