Looking for hinged 3 bolt exhaust flange
I'm not sure these even exist but if they do can someone point me in the right direction to obtain a few. I need to put a flange on an existing flared exhaust.
Thanks in advance,
David
Thanks in advance,
David
NAPA sells those. no hinge but a bolt and nut on both side. exacly the shape you put up otherwise. I might even have one kicking around if you can't find it on your own.
I'm making a set of equal length headers with Burn's 304 stainless steel mandrel bends and Burn's 304 stainless steel 5-1 merge collectors.
I want them to be able to bolt up to the stock exhaust which has a ball type collector, and I'd like to be able to change the stock flange on the stock header-back exhaust without cutting up the stock exhaust piping. So by removing the stock flange which isn't the typical bolt circle for a 3-bolt flange and putting on a new 3-bolt flange everything would bolt up peachy.
I just want whoever buys these to be able to use the stock exhaust if they want or they could bolt up an aftermarket exhaust that would connect at the stock manifold.
I think I have something better in mind though.
(These headers are for a vehicle on our site.
I want them to be able to bolt up to the stock exhaust which has a ball type collector, and I'd like to be able to change the stock flange on the stock header-back exhaust without cutting up the stock exhaust piping. So by removing the stock flange which isn't the typical bolt circle for a 3-bolt flange and putting on a new 3-bolt flange everything would bolt up peachy.I just want whoever buys these to be able to use the stock exhaust if they want or they could bolt up an aftermarket exhaust that would connect at the stock manifold.
