question about itr ecu?
Old Dec 6, 2004 | 01:53 PM
kennethe's Avatar
Default question about itr ecu on a gsr b18 motor?
I was wondering if helps or hurts a gsr b18c to have a itr ecu? would the gsr ecu make it run better than the itr ecu? thanks
Modified by kennethe at 3:04 PM 12/6/2004
Old Dec 6, 2004 | 03:05 PM
AznInvasion's Avatar
Default Re: question about itr ecu on a gsr b18 motor? (kennethe)
if u got a gsr just stick with the gsr ecu but if u are running a skunk 2 manifold on your gsr get the ITR.
Old Dec 6, 2004 | 04:15 PM
PIC Performance's Avatar
Default Re: question about itr ecu on a gsr b18 motor? (AznInvasion)
P73 would not help even with the Skunk2 IM because vtec engagement is set too high for stock gsr cams, 5700 vs 4400.
Only reason to get an ITR ecu is if you are getting a single-stage IM (aka anything other than the GSR IM), and ITR/CTR cams.
Old Dec 6, 2004 | 04:25 PM
kennethe's Avatar
Default Re: question about itr ecu on a gsr b18 motor? (Noob4life)
thanks, I was just wondering since when I bought the car it came with the itr ecu and it is a jdm b18c obd2 motor. I was thinking of putting some ctr cams or possibly skunk 2 stage 2 cams not sure though what would be best.
Old Dec 6, 2004 | 04:34 PM
JDM ITR or JDM GSR engine? If it is indeed a jdm b18c then I suppose the itr ecu belongs there.
Old Dec 6, 2004 | 04:46 PM
kennethe's Avatar
yeah it is a jdm gsr. Do you think it would run well with the ctr cams? thanks
Old Dec 6, 2004 | 07:29 PM
Chewie's Avatar
jdm b18c could be a r motor
TealEG!
Mar 7, 2008 01:44 PM
touchmyHONDA
17
Mar 30, 2006 11:50 AM
hondamanwill
Sep 22, 2002 06:32 AM
1 speedstar
Aug 14, 2002 08:21 PM
12345
Jul 28, 2002 08:54 PM
