Differences in rear crossmembers?
Old Dec 6, 2004 | 01:31 PM
Fred n J_v2.0's Avatar
Default Differences in rear crossmembers?
Is the rear crossmember on an automatic 88-91 civic hatchback different than a manual tranny one?
Thanks in advance,
-j
Old Dec 6, 2004 | 01:38 PM
dr_latino999's Avatar
Default Re: Differences in rear crossmembers? (Fred n J's_1.8's)
I think the rear mount is in a different location but if someone can verify this, bump for answer
Old Dec 7, 2004 | 07:30 AM
Default Re: Differences in rear crossmembers? (dr_latino999)
Anyone else with some info?
Old Dec 7, 2004 | 07:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Honda part numbers are the same for the left and right side. The front and rear are different. Rear mount goes into a diffenent set of holes in the rear cross member.
Take a look for at the part numbers for yourself -
Part Numbers
Just change the transmission type to KL4AT for automatic. Under "System\Component" find "Engine Mount"</TD></TR></TABLE>
Old Dec 7, 2004 | 07:45 AM
Putput's Avatar
If you converting froma auto to manual, I did it on my 91 DX auto to B16a manual with out a problem. In fact, I didn't really have to bang or bent anything to fit. I just HASPort mounts, if that helps.
Best regards,
Bryant Fong
Old Dec 7, 2004 | 08:12 AM
Default Re: Differences in rear crossmembers? (Putput)
Ok, just cross-referenced the parts for an automatic and a manual.
Same part number so I assume they are the same. Only possibly difference maybe if it is equipped with powersteering or not.
Rear Crossmember part # is 50200-sh9-a00
same for automatic and manual.
Thanks guys
-j
Your Name
Nov 1, 2009 01:23 PM
boosted97civic
Apr 27, 2007 09:27 AM
wfocrx
May 17, 2006 07:46 PM
DB82NR
Apr 2, 2006 04:16 PM
