wiring resistor box for obd2..
Old Dec 6, 2004 | 12:52 PM
VRD^don's Avatar
Default wiring resistor box for obd2..
okay..i know that the dead end plug is on the back of the intake manifold..okay i found it but theres 2 two dead end plugs..was wondering which one do i tap into..theres a blue one and a gray plug..which plug do i tap in to.,.
Old Dec 6, 2004 | 01:29 PM
showbiz's Avatar
Default Re: wiring resistor box for obd2.. (sohc_vtec)
Are you converting to obd1 or using peak and hold injectors? What engine harness are you using?
Old Dec 6, 2004 | 09:10 PM
MaxBoostC1's Avatar
Default Re: wiring resistor box for obd2.. (sedanman)
gray plug
Old Dec 7, 2004 | 09:49 AM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sedanman &raquo;</TD></TR><TR><TD CLASS="quote">Are you converting to obd1 or using peak and hold injectors? What engine harness are you using?</TD></TR></TABLE>
not converting..using dsm injectors..
Dorkenheimer
Dec 14, 2014 03:37 PM
MMMGIRL
Jan 17, 2012 11:39 AM
Beau Gotti
Nov 30, 2007 03:02 PM
ef8sleepr
Feb 23, 2006 09:25 PM
