Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Realtime style brake cooling ducts
Old Dec 6, 2004 | 12:33 PM
BigAl's Avatar
Default Realtime style brake cooling ducts
I am after a set of brake cooling intaked ducts to fit a 98 - oem usdm style front .
Noticed in a photo of one of the last Realtime DC Integras that they had what looked like carbon moulded ''funnels'' each side of the radiator intake.
This exactly what I am after .
I have emailed Realtime and as usual had no response.
Anyone have any idea who I could get a set from as I have no idea who does Realtimes moulding or who the Realtime cars were sold too.
Old Dec 6, 2004 | 12:37 PM
slammed_93_hatch's Avatar
Default Re: Realtime style brake cooling ducts (BigAl)
if you check some of the circle track racing web sites, they have ducts that will work, there not nifty carrbon fiber though.
Old Dec 6, 2004 | 01:00 PM
CivicSiRacer's Avatar
What would you possibly need them for other than track days and road racing?
Old Dec 6, 2004 | 01:13 PM
Fate's Avatar
J's racing might have them for you. They have them for EGs so they could have them for the teg
Old Dec 6, 2004 | 01:30 PM
BigAl's Avatar
Default Re: Realtime style brake cooling ducts (slammed_93_hatch)
am familar with the butler style ducts, but still quite a bit of work required to get an airtight fit around the front .
Something similar to the realtime duct would make it a simple and tidy fix
Old Dec 6, 2004 | 01:38 PM
.RJ's Avatar
.RJ
Default Re: Realtime style brake cooling ducts (CivicSiRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRacer &raquo;</TD></TR><TR><TD CLASS="quote">What would you possibly need them for other than track days and road racing?</TD></TR></TABLE>
Isnt that why you'd want them?
RJ - who doesnt understand the question, and would like some also
Old Dec 6, 2004 | 01:57 PM
GBRacing's Avatar
Default Re: (BoostedB16EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedB16EG &raquo;</TD></TR><TR><TD CLASS="quote">J's racing might have them for you. They have them for EGs so they could have them for the teg</TD></TR></TABLE>
Who's J's racing? Website?
Old Dec 6, 2004 | 02:03 PM
BigAl's Avatar
Default Re: (ITACRX)
Most of the JDM Integras have brake ducts built in to the front moulding so unlikely that J's or anyone else will be able to help
No one with any contacts at Realtime? Thought that they would be getting someone to do their moulding work and they may still have the moulds.
Old Dec 6, 2004 | 04:14 PM
stormy's Avatar
use epoxy to bond the ducts to the bupmper if you need a better fit
Old Dec 6, 2004 | 04:24 PM
Default Re: (BigAl)
why do you HAVE to have the ones that real time uses?
as i said befor check out circle track racing website and you can find um.
in fact here is some links to a few
http://www.pitstopusa.com/sear...D=547
http://www.bakerprecision.com/brkduct.htm
http://www.racerpartswholesale.com/
make some messurements and you can find something that will work for you.
Old Dec 6, 2004 | 07:29 PM
FormulaIntegra's Avatar
Default Re: (slammed_93_hatch)
I got mine from Pegasus. Real easy to work with.
http://www.pegasusautoracing.com
Old Dec 6, 2004 | 07:45 PM
BigAl's Avatar
[QUOTE=slammed_93_hatch]why do you HAVE to have the ones that real time uses?
I would like ducts the same/similar as realtime used because;
They will fit my application without modification as I use the same nose cone and the same radiator ducting.
I will be able to remove the nose cone quickly without having to mess about with cooling hoses
they will work correctly.
It will save me time with making mould etc.
I do not care if they are Realtime or not and carbon or fibreglass is ok.
We are in the middle of our race season down here in New Zealand and things are pretty busy at the moment so anything we can purchase ready made is a bonus.
Old Dec 6, 2004 | 10:47 PM
Erik95LS's Avatar
Default Re: (BigAl)
if you want something ready made, then you may want to check with Colletti Motorsports, although I don't know about shipping to New Zealand. Here is their ducting system. It also includes a deflector plate.
Colletti Motorsports Cooling Ducts
Old Dec 7, 2004 | 05:41 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">why do you HAVE to have the ones that real time uses?</TD></TR></TABLE>
Well I don't know about him, but so far Real Time is the only ones I see that actually direct air into the hats through the vents/veins in the rotors instead of just directing airflow somewhere more towards the shock fork then anything else. I'm sure all WCTC cars use this method, but this is the only way to do it and Real Time did it right for a FWD car and still have clearance for axle and turning. I don't NEED the ones Real Time has, but I'm copying their design for sure. See here....
edit: Changed for semantics.
Modified by Mr Hammond at 12:48 PM 12/7/2004
Old Dec 7, 2004 | 05:44 AM
.RJ's Avatar
.RJ
Default Re: (Mr Hammond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote"> but I'm copying their design for sure. See here....
you have an NSX?
Old Dec 7, 2004 | 06:08 AM
ryan12321's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">you have an NSX? </TD></TR></TABLE>
did the nsx become front wheel drive? I see an axle in there.
Old Dec 7, 2004 | 06:12 AM
Honda318dx's Avatar
Default Re: (.RJ)
J00 blind smartass..
RSX maybe...
Old Dec 7, 2004 | 06:16 AM
.RJ's Avatar
.RJ
Default Re: (Honda318dx)
&lt;-----
Old Dec 7, 2004 | 06:20 AM
phat-S's Avatar
Well I don't know about him, but so far Real Time is the only ones I see that actually pressurize the rotors instead of just directing airflow somewhere more towards the shock fork then anything else. </TD></TR></TABLE>
Perhaps this is just a semantics argument but ducts, no matter how they are situated, will not "pressurize" air to the hats. Air flow into the rotors will be limited by the narrowest section of duct and/or the air inlet on the duct.
Old Dec 7, 2004 | 08:45 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">RSX maybe...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phat-S &raquo;</TD></TR><TR><TD CLASS="quote">Perhaps this is just a semantics argument but ducts, no matter how they are situated, will not "pressurize" air to the hats. Air flow into the rotors will be limited by the narrowest section of duct and/or the air inlet on the duct.</TD></TR></TABLE>
Yeah I guess I didn't mean in the literal sense of the word. More so that air is actually directed into the hats of the rotor and through the cooling veins/vents and would be a lot more effective then simply a 2.5"-3" hose aimed somewhere at the front suspension more or less. Either way I've just often wonder why no company has really capitalized on the lack of efficient brake duct/cooling kits offered with the sub-par products I've seen available.
Old Dec 7, 2004 | 09:02 AM
Tyson's Avatar
you need to consider why it looks so simple on the realtime RSX. its because its a macpherson strut suspension. theres no knuckle to get in the way of the rotor, plus that rotor is oversized making the diameter of the top hat bigger to allow more gap for air to be directed in. if only it were so easy in our double wishbone IT cars...
Old Dec 7, 2004 | 09:30 AM
phat-S's Avatar
Are you sure its a lot more effective? I know on my CRX, the opening available to us to get air "directly" into the hats is at best a 2"x1" crescent. Unless the rotation of the veins forces air through the air inlet, I think we'd be limiting the effectiveness of our 3" ducts to a 2" x 1" outlet. Might be more effective to blow 3" worth of air on anything you can get to in there. Just a thought and I ain't that down w/ Bernoulli and friends so I'd be happy to be wrong on this.
Now I have seen guys split off their 3" ducts into segments and if one went to the hats, that might be a good alternative provided the other two go somewhere useful. But still, nothing I am saying should be taken as "fact" its just guessin'.
Old Dec 7, 2004 | 01:35 PM
bdb's Avatar
bdb
Default Re: (phat-S)
RealTime RSX...
Unfortunetly, the DC2 has a lot of stuff in the way and no clear and easy way to make a backing plate to force air through the rotor.
http://www.sandmracing.com/m_b05_ducts.html tried to make a set, but as shown it's quite awkward to use even a 2" hose onto a backing plate.
Old Dec 7, 2004 | 04:58 PM
cbstd's Avatar
Here is a little secret:
Go to Home Depot and buy some ShopVac nozzles. They work plenty good as brake ducts.
Scott
Old Dec 7, 2004 | 04:59 PM
.nate's Avatar
Wow great pics!
