Knocking Sound From Suspension ?
My 91 Hatch is making a knocking/rattling sound that seems to be comming from the passenger side suspension. It has been doing that since i bought the car stock. Since the b16 swap, and lowering it got worse. I knew that i blew the shocks with some cheap *** coilovers so i replaced them with Tein SS dampers and figured that would take care of the problem. Not quit. Axels are new, bushings look ok. Not sure if it could be the hub bearing or maybe the tie rod. Any suggestions?
if axles/bushing look good then i'd check tie rods (inner AND outer), as well at upper and lower ball joints. Hub bearings usually make a whirring sound while driving/turning in opposite direction as affected wheel.
Vince
Vince
stangnick
Jan 16, 2010 03:48 PM
hybrid90
Suspension & Brakes
14
Feb 27, 2008 03:35 PM
mattb16a1civic
12
Jan 21, 2004 02:11 PM
