How can you tell if a strut or shock for a Accord is bad?
Old Dec 6, 2004 | 08:55 AM
rillboss's Avatar
Default How can you tell if a strut or shock for a Accord is bad?
I have a used set of KyB's and Progress springs and I want to know if there is a way check them to see if they are good or not before I put them on my car.
Old Dec 6, 2004 | 08:58 AM
vtecaccord 1's Avatar
Default Re: How can you tell if a strut or shock for a Accord is bad? (rillboss)
if you look around the cylinder and you can see that the fluid is leaking out of it then it needs to be replaced.
Old Dec 6, 2004 | 09:24 AM
SuperSlow's Avatar
before you put them in, just take the setup if it is assembled and push down on it. If the thing takes forever to come back up, then you have a problem.
Old Dec 6, 2004 | 10:11 AM
brads94accord's Avatar
or in my case if the shock is on your car, when you hit a bump the right rear shock and spring rebounds and bounces really fast and hard.
Old Dec 6, 2004 | 10:53 AM
Nick M's Avatar
Default Re: (brads94accord)
knocking, unsettling movements and unbalance in the ride
byrne_06
Jun 29, 2011 10:29 AM
AmericanPie
Suspension & Brakes
Nov 28, 2010 04:40 PM
littledude56
Suspension & Brakes
May 6, 2009 03:47 PM
jimby452
Feb 27, 2003 06:49 AM
LshatchTurbo
Nov 10, 2001 03:12 PM
