doin an odd mpfi swap will this work?
Old Dec 6, 2004 | 08:43 AM
n2oef's Avatar
Default doin an odd mpfi swap will this work?
got a 90 lx that i have a d16z6 in can i use the obd1 injectors and distributor with a obd 0 ls ecu?will it run enough to tune with a vafc?anyone know gear ratios on the cable d series tranny's?
Old Dec 6, 2004 | 09:10 AM
dr_latino999's Avatar
Default Re: doin an odd mpfi swap will this work? (n2oef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n2oef &raquo;</TD></TR><TR><TD CLASS="quote">got a 90 lx that i have a d16z6 in can i use the obd1 injectors and distributor with a obd 0 ls ecu?will it run enough to tune with a vafc?anyone know gear ratios on the cable d series tranny's?</TD></TR></TABLE>
1) You can't use OBD-1 injectors with a PR4. Especially if you use the Z6s distributor. Best bet would be to keep the injectors, find a P28 and convert it over to OBD-1. Save you a lot of trouble and hassle down the line.
2) Gear ratios:
HF --&gt; 3.250 1.650 1.033 0.823 0.694 FD: 2.954 (California: 3.25)
DX --&gt; 3.250 1.894 1.259 0.937 0.771 FD: 3.88
SI --&gt; 3.250 1.894 1.259 0.937 0.771 FD: 4.25
Old Dec 6, 2004 | 10:06 AM
n2oef's Avatar
Default Re: doin an odd mpfi swap will this work? (dr_latino999)
cant u use obd0 injectors w/a resistor box on obd1 though?
why couldnt i use obd1 injectors w/o resistor box?do u know what resistance is in the resistor box?i have a set of obd 0 injectors to use but no box so could i just hit up radio shack?
Old Dec 6, 2004 | 10:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Notorious B &raquo;</TD></TR><TR><TD CLASS="quote">you can solder in the 10w 10 ohm resistors in line with each yellow/black wire to the resistor, if you do it right you can get them to tuck right back in with the stock injector wiring, and you can't even see them. I was even able to get the plastic wire "trim" back around all the wiring, can't even tell the resistors are there.</TD></TR></TABLE> Or you can hit up your local auto salvage yard and yoink a resistor box, it's up to you.
Old Dec 6, 2004 | 10:34 AM
n2oef's Avatar
ok thanks-i couldnt seem to find the info......
brock316
Jan 11, 2011 09:07 PM
honcrx91si
Aug 8, 2005 09:34 PM
Power Rev Racing
Jul 27, 2005 05:12 PM
04falcon
Dec 5, 2004 07:00 PM
GSRontheBottle
Jan 1, 2004 04:32 PM
