Air Filters for ITB's ?
Old Dec 6, 2004 | 08:19 AM
mechatune's Avatar
Default Air Filters for ITB's ?
anyone here using air filters for their ITB's ? (i need them for TWM 50mm)
if so, where can i get them ?
oh, and post PICS please!
Old Dec 6, 2004 | 10:50 AM
mechatune's Avatar
anyone ? *yawn
Old Dec 6, 2004 | 11:37 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: (mechatune)
twm makes an actual plenum for the manifold, it allows use of an intake arm. compnaies sell filters, one is ITG i think
Old Dec 6, 2004 | 08:04 PM
dohcsideracer's Avatar
Default Re: Air Filters for ITB's ? (mechatune)
I am getting the ITG JC50-65 for my ITB's. They also sell blank base plates, that you can drill to fit your set up, and mount the foam filter to it.
check: http://www.itgfilters.com/ for more info...
Hope it helps.
Adrian
Old Dec 7, 2004 | 06:34 AM
mechatune's Avatar
i've seen someone w/ k&n filters. the same guy selling short 'red velocity stacks'
i'd like to know the model number, or if someone can post pictures up...
Old Dec 7, 2004 | 09:02 PM
Tbone's Avatar
This is an itg setup for twm 50's I never ended up running them.
Old Dec 8, 2004 | 07:58 AM
mechatune's Avatar
i ended up getting this set.
Old Dec 8, 2004 | 08:36 AM
Tbone's Avatar
From where ? I need some for my Jenveys...
Old Dec 8, 2004 | 08:48 AM
DOHCsideracing's Avatar
For what its worth... I have heard that the oiled cotton/K&N style filters are not as efficient at filtering out the fine particles as the oiled foam filters are or even the paper elements.
For a race motor I bet the K&N's are fine, but for something that is going to see a ton of miles (like my car), I'll be putting an ITG filter on.
Not trying to get a big debate started, just relaying what I have heard...
Old Dec 8, 2004 | 09:03 AM
stockredej1's Avatar
when you get those on post up a pic
Old Dec 9, 2004 | 06:13 PM
sykotik sol's Avatar
Default Re: Air Filters for ITB's ? (stockredej1)
did you guys actually gain any hp/tq from itb's, just wondering?? do they actaully make a big difference for how much they are...? thanks
Old Dec 9, 2004 | 07:03 PM
kaptr1d's Avatar
Default Re: Air Filters for ITB's ? (sykotik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotik sol &raquo;</TD></TR><TR><TD CLASS="quote">did you guys actually gain any hp/tq from itb's, just wondering?? do they actaully make a big difference for how much they are...? thanks</TD></TR></TABLE>
itbs arent just for looks u know. lots of throttle response and additional power on the top end...
Old Dec 9, 2004 | 07:44 PM
rodrez.'s Avatar
Default Re: (Tbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">This is an itg setup for twm 50's I never ended up running them.
My friend uses this kit on his A-spec ITB's
Old Dec 9, 2004 | 10:14 PM
Aquafina's Avatar
Default Re: (rodrez.)
Wouldn't using a plenum w/arm make tuning even more of a problem? It'd be like tuning 2 engines, or would the removal of the plenum at tracks not make much of a difference tuning wise?
Old Jan 15, 2005 | 09:24 PM
lohatch's Avatar
back from the dead.......where did you purchase these from and what did they end up running you??? any links would be appreciated. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mechatune &raquo;</TD></TR><TR><TD CLASS="quote">i ended up getting this set.
Old Jan 15, 2005 | 09:47 PM
hayabusa160's Avatar
Default Re: Air Filters for ITB's ? (lohatch)
i was lookin in some pics i found at my cousins house.
and i found a very intresting way some guys put filters on their toyota motors running itbs.
rember the ricers days the front mount intake things?
they used something that looks like that and mounted it on their itbs i thought it was pretty ingenious.
i'll try and get the pic next time im over.
Old Jan 15, 2005 | 11:14 PM
DSRxCandyh2bEG's Avatar
those are hella clean looking. im curious on the price of those and where to get them too. wonder if they work for h series? looking for itbs right now...
Old Jan 16, 2005 | 12:12 AM
92TypeR's Avatar
FSAE
Default Re: Air Filters for ITB's ? (AVRh22EG)
Don't get individual filters.
You will create a more responsive lower end with more power by using a plate + plenum. Having the plate in front of the velocity stacks improves standing velocity...
You can make your own, or TODA makes one that bolts onto their ITB's.
Old Jan 16, 2005 | 08:11 AM
lohatch's Avatar
Default Re: Air Filters for ITB's ? (92TypeR)
have you dynoed it with open velocity stacks and then with the plate/plenum setup??? i will be running weber sidedrafts and i am just looking to get some filters that i can put on the end of my velocity stacks for daily driving. i might end up running some foam style filters from shifter carts or something like that. just wanted to see what he paid for those K&Ns, because usually they are in the $20-$30 range per single filter like that.
Old Jan 16, 2005 | 08:34 AM
92TypeR's Avatar
FSAE
On a car, no. But there was a constant 4-6hp over individual filters from 2000rpms to 7000rpms, and about 3-4hp from 7000 to redline on a '02 Suzuki GSX-R 750.
Old Jan 16, 2005 | 09:13 AM
lohatch's Avatar
too bad tbone didnt do a dyno comparison with the filter on his ITBs. would have been some more good info.
Old Jan 17, 2005 | 08:43 AM
lohatch's Avatar
anybody else out there want to share their filtration contraptions for their ITBs or carbs..............................somebody has to have more info!!!!
Old Jan 23, 2005 | 08:27 PM
Check this out... This is a ITG JC50/65, which should be the one TBone was showning.
Its pretty close to the brake MC, but it fits...
fabworxs
Jan 15, 2007 03:01 PM
fabworxs
Sep 13, 2006 07:27 PM
tanklee
Apr 7, 2006 01:27 AM
passinUby
Nov 18, 2002 09:10 AM
