am i running rich?
Old Dec 6, 2004 | 08:02 AM
DriveSlowHomie's Avatar
Default am i running rich?
when my car is running...it does smell excessivelly like gas....and i notice after awhile inside my windshield you can see oil buildup like the rainbow colors...i have a gsr with some bolt ons and a chip ecu....could the chip ecu be the problem?...my car also eats alot of gas...like maybe like 220 per tank...any advice or experience with this problem will be greatly appreciated
Old Dec 6, 2004 | 08:09 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: am i running rich? (cmGSR916)
What bolt ons do you have? Your chipped ECU seems to be the culprit, as it is really the only thing you listed that can actually alter your fuel delivery somewhat. However, it's hard to say without more information.
How many miles are on your car? Did you do all the regular maintenance on it, such as spark plugs, ignition wires, cap/rotor, etc? Are you throwing any codes?
Old Dec 6, 2004 | 08:12 AM
HONDA RR's Avatar
It seems like the ecu is giving you the problem.
Old Dec 6, 2004 | 08:30 AM
Default Re: am i running rich? (MITSUBA)
i do regular maintainence on my car....bolt ons are just like headers, intake, exhaust...plug wires...just changed spark plugs not so long ago to ngk laser platinums....ummm...thats all i can think of except for act clutch and type r tranny but i know those dont affect anything with running rich....the only thing i can think of is my chipped ecu...im thinking of rechipping it with a different setup...see if it helps...thanks for the info
Old Dec 6, 2004 | 08:46 AM
shamoo's Avatar
Okay....it seems you are pretty stock. So I going to assume that it's your ECU. However, it could be another problem. It just seems to be your ECU.
What kind of "chipped ECU" is it? With your modifications, I'd stay with your stock ECU. Try putting your stock one back in (unless it's your stock one that was "chipped") and see how your car changes.
Old Dec 6, 2004 | 11:23 AM
hybrid_vtec's Avatar
Default Re: am i running rich? (shamoo)
I have been having the same problem! I am going to set mine back to stock and just go get it tuned with my SAFC 2!
What ECU is it? For OBD-1 USDM ECU's just clip the J1 jumper wire and it will go back to factory settings.
These links should help you out!
<FONT COLOR="red">USDM</FONT> P06/PR4/P28/P30/P75/P72/P91/PR3-J01 ECUs (large case OBDI)Click Here
<FONT COLOR="blue">JDM</FONT> P08/P30/P70/P71/P72 ECUs (small case OBDI)Click Here
<FONT COLOR="green">USDM</FONT> P13/<FONT COLOR="green">JDM</FONT> P13 (large case OBDI) / <FONT COLOR="green">JDM</FONT> PR3/PW0/PR4/PM6/PM7Click Here
JdmJboog
Apr 14, 2015 02:55 PM
PBsTREETracer
Apr 12, 2008 06:39 PM
crapanese
Aug 7, 2006 11:40 PM
boostedeghatch
Feb 13, 2005 12:27 PM
