hesitation/ lurching/ misfiring/ bogging @ hwy cruising - new hondata s200 user...
Old Dec 6, 2004 | 07:09 AM
Black R's Avatar
25 Year Member
Default hesitation/ lurching/ misfiring/ bogging @ hwy cruising - new hondata s200 user...
Ok, the basics first:
b18c5 motor and tranny with 4.9 final drive
obd2 wired car with obd2 to obd1 harness and p28 s200
toda spec c cams (@ 0,0)
hytech header
short ram intake
2.5" mandrel exhaust
Street tuned to 13.5-14:1 with wideband.
The cams idle at columns 5 and 6 instead of the 1-2 range where the stock cams idled.....very low vacuum at idle.
The idle we kinda got worked out by advancing the timing and leaning out the fuel from a tuned itr cams map given to me by a friend.
But we couldn't get the lurching to go away on the hwy...
This is cruising between 3800-5200 rpms - which is 65mph to 85mph roughly in 5th gear with my tranny and final drive. I noticed this is between 1 and 10% throttle. It happens a lot between 2% and 6% throttle just cruising at those rpm/ mph.....
What should we check to get rid of this "stumble?"
It is quite annoying.
And if anyone has a stock itr motor with spec c map, please send it to me!
Old Dec 6, 2004 | 07:36 AM
sammysnakes's Avatar
Default Re: hesitation/ lurching/ misfiring/ bogging @ hwy cruising - new hondata s200 user... (Black R)
have you been able to check what your A/F ratio is while cruising?
and when you say you advanced the timing, i'm guessing you mean ignition?
Old Dec 6, 2004 | 09:17 AM
Black R's Avatar
25 Year Member
Default Re: hesitation/ lurching/ misfiring/ bogging @ hwy cruising - new hondata s200 user... (chainsaw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chainsaw &raquo;</TD></TR><TR><TD CLASS="quote">have you been able to check what your A/F ratio is while cruising?
and when you say you advanced the timing, i'm guessing you mean ignition?</TD></TR></TABLE>
a/f was ~14.5 cruising...
yes I meant ignition timing. Cams are still at 0,0 for this baseline tune.
TomCat39
Engine Management and Tuning
Aug 2, 2016 11:19 AM
racebum
Apr 10, 2012 05:07 AM
eg6madness
20
Nov 29, 2010 08:29 PM
Mura
Jul 30, 2007 09:09 AM
93gsrcoupe
Aug 13, 2004 06:04 PM
