CTR Cam Power Gains
Old Dec 6, 2004 | 02:19 AM
1SlowSi's Avatar
Default CTR Cam Power Gains
I am currently running a B16a2 with Si cams. Will I notice any power gains/loss just by throwing in CTR cams and leaving the gears at 0,0? Im not going to tune it just yet, but i dont want to lose power either during the time off the dyno.
Any settings you guys know that work like +2,0?
Old Dec 6, 2004 | 09:53 PM
asilaydying1984's Avatar
bump
Old Dec 6, 2004 | 09:56 PM
Default Re: CTR Cam Power Gains (1SlowSi)
i would like to know the same thing
Old Dec 6, 2004 | 11:05 PM
1SlowSi's Avatar
Default Re: CTR Cam Power Gains (asilaydying1984)
bump for some help!
Old Dec 7, 2004 | 12:17 AM
UncleD's Avatar
I would say so. the usdm cams are really mild, if you put the ctr cams in you should notice an increase. For instance, the Skunk 2 stg.1 cams on the intake side are almost an exact dupplicate of the ctr intake cam, really the only difference is the skunk has more lift/duration on the exhaust side. Your vtec crossover will feel stronger, but will still obtain the factory idle. Great low budget cam choice. FYI : Import Builders built an ls/vtec that laid down OVER 200 wheel horse to the ground, ended up running like a low to mid 12 on "type r" cams, not sure which ones, but the fact is that Honda know's what they are doing. Also, what are your ulimate goals??
Old Dec 7, 2004 | 04:11 AM
1SlowSi's Avatar
Default Re: CTR Cam Power Gains (clean rice)
So you are saying yes to gaining overall power with just putting them in and leaving at 0,0 for adv/ret?? I know i can get more from the dyno, but for now im just putting them in. My goals.. ha, 400+ hp with my new turbo setup, right now, im still all motor with this one.
Old Dec 7, 2004 | 04:27 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
I had CTR cams in my LS/VTEC the car was not tuned but they felt good mid-range
i liked them- not compared to bigger after market cams, m24's for me
Old Dec 7, 2004 | 07:39 AM
so are you guys saying they will make more power without adjusting them just throwing them in and doing a valve adjustment?
Old Dec 7, 2004 | 11:22 PM
1SlowSi's Avatar
Default Re: (asilaydying1984)
It doesnt seem like this question is being answered correctly. I know they will pull nicely but will the CTR cams give me MORE power overall than my Si cams? BOTH at 0,0?????
Old Dec 8, 2004 | 03:35 AM
Throwdown's Avatar
Default Re: (1SlowSi)
yes
Old Dec 8, 2004 | 04:05 AM
1SlowSi's Avatar
Default Re: (DBL)
thanks
Old Dec 8, 2004 | 07:43 PM
dcvt16's Avatar
what about valvetrain problems such as valve float w/ the b16 valve spings? is that an issue?
Old Dec 8, 2004 | 08:09 PM
Default Re: (dcvt16)
no
Old Dec 8, 2004 | 09:17 PM
hondaeg8's Avatar
i have a CTR intake cam on my gsr motor, currently for sale, and i felt a difference when i drove the car after the install. its not a bad upgrade.
i want to go with s2s1's now, but since in an earlier post, somebody stated that the s2s1 intake is like the CTR intake cam, don't know if its even worth it. maybe i should just get an ITR exhaust cam since i'm still using my gsr exhaust cam.
i think the CTR cam is worth the buy. just don't go reving your motor past the stock redline.
Old Dec 8, 2004 | 09:58 PM
JDMstance99's Avatar
Default Re: (hondaeg8)
on my b16a2 i had a ctr intake cam,exedy stage 1 clutch, xact prolite flywheel, and a usdm itr ecu and ran a 15.1 with a horrible 60 fot due to bald tires, the cam and the ecu worked great togehter!
Old Dec 8, 2004 | 09:59 PM
Default Re: (JDMstance99)
ps: i revved to 9k on stock valvetrain for over 30k miles and was good!
Old Dec 9, 2004 | 09:55 AM
what car was that in becasue that is pretty slow?
Old Dec 9, 2004 | 07:33 PM
yea real slow for a ctr intake cam clutch flywheel and ecu with a horrible 60 ft
too bad u dont kno anything, i dont know what gains your expecting with an intake cam
what car do you drive and what was your pass on the track?
its in a 99 civic si
Old Dec 9, 2004 | 07:48 PM
99 TYPE R's Avatar
that is week in my si i went 14.7 with an r trans and act clutch,skunk 2 ecu and full exhaust
Old Dec 10, 2004 | 12:57 AM
hondaeg8's Avatar
Default Re: (99 TYPE R)
yeah...that is pretty weak for an si :hehe:
Old Dec 10, 2004 | 02:14 AM
1SlowSi's Avatar
what would you guys guess ide run in a 1/4?
DC 4-2-1 headers
DC Full cat back exhaust
CTR intake/exhaust cams
Action 2MD clutch
I have Hondata too but its a base map. The turbo is going on very very soon! hense the clutch. haha.
Old Dec 11, 2004 | 07:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMstance99 &raquo;</TD></TR><TR><TD CLASS="quote">on my b16a2 i had a ctr intake cam,exedy stage 1 clutch, xact prolite flywheel, and a usdm itr ecu and ran a 15.1 with a horrible 60 foot due to bald tires, the cam and the ecu worked great togehter! </TD></TR></TABLE>
it was also my first run at the track
if anything it was that, the car wasnt slow, i ran 4 differnt srt 4's and beat them all, they had intake but thats not bad for a 1.6l all motor with bullshit internals compared to a turbo str 4
Old Jan 27, 2005 | 09:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMstance99 &raquo;</TD></TR><TR><TD CLASS="quote">yea real slow for a ctr intake cam clutch flywheel and ecu with a horrible 60 ft
its in a 99 civic si</TD></TR></TABLE>
lol i drive a crx , thats why i thought your time was slow, i thought you were going to say you drove a hatch or a crx and that would have been a horrible time, but it looks like from what these people are saying your time sucked anyways
Old Jan 27, 2005 | 09:57 PM
bambbrose's Avatar
maybe elevation is why he is slower. 15.1 is respectable all motor around here
Old Jan 28, 2005 | 12:01 AM
EG6R's Avatar
TypeR cams are good upgrades for a B16. ITR is what i have now, i really would have wanted CTRs but theyre more expensive and i didnt have enough money then. My B16 EG managed a 13.9, stock head and standard bore, I/H/E +ecu.
