welding aluminum
From: gravity rides everything...everything will fall, se GA/ne FL
sure it's possible and it's not as nice as tig, but it works. get a pull type/spool gun if you don't change your steel coiled liner. you can use the gun you got now and just put a nylon liner. use straight argon. dc-reverse polarity (+contact tip, -ground/work) and play with the settings on some scrap pipe and sheet of aluminum.
yeah it's just so it doesn't kink as easy. i don't see why you can't use steel wire through the nylon. you also want to keep the length as short as possible.
96 GSR-T
Welding / Fabrication
Apr 12, 2010 05:09 AM
