why are these welders the same price?
Old Dec 5, 2004 | 08:01 PM
SHystrdyGSRtdy's Avatar
Default why are these welders the same price?
i thought you wanted a higher AMP rating? and a higher duty cycle? with that being said, why are these two the same prices?
http://www.harborfreight.com/c...43028
http://www.harborfreight.com/c...43025
btw, are these good enough to do say, turbo manifold and exhaust piping?
Old Dec 5, 2004 | 09:04 PM
triple_s1x's Avatar
Default Re: why are these welders the same price? (SHystrdyGSRtdy)
omg dont even bother with those, i used the first one you listed at a buddies shop for a couple minutes and its the absolute biggest pos i ever used. The cable dealy in the gun kept catching on the wire and messing up the whole operation.
Old Dec 6, 2004 | 10:25 AM
Default Re: why are these welders the same price? (triple_s1x)
but aren't the specs good? as in 230V @ a higher amp rating?
Old Dec 6, 2004 | 10:33 AM
RCautoworks's Avatar
The specs might be good but I would not spend that much money on a harbor freight welder.
Look around some more because you can by a nice lincoln or hobart welder for that price.
Old Dec 6, 2004 | 10:55 AM
Default Re: why are these welders the same price? (90blackcrx)
a lincoln or hobart with those specs?
Old Dec 6, 2004 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">a lincoln or hobart with those specs?</TD></TR></TABLE>
I know you can get one that is a 110 volts and its gonna be better then those 2, the lincoln I bought was the weld pac 100 and it can weld up to 1/4'' of metal
Old Dec 6, 2004 | 11:25 AM
if you don't mind me asking, how much was your lincoln? will it be sufficient to weld together a turbo manifold and exhaust?
Old Dec 6, 2004 | 11:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">if you don't mind me asking, how much was your lincoln? will it be sufficient to weld together a turbo manifold and exhaust?</TD></TR></TABLE>
Yes it will be more then enough, I know sears sells the kit for 350 but you can find some coupons and get it for around 325. I paid 250
Old Dec 6, 2004 | 01:52 PM
thanks
Old Dec 8, 2004 | 08:31 PM
Snail EK's Avatar
i'd buy it
Old Dec 8, 2004 | 10:37 PM
Engloid's Avatar
OG Fabricator
You're better off with a used Miller, Hobart, or Lincoln...than with a new hunk of **** from Harbor Freight.
Old Dec 9, 2004 | 12:36 AM
Kookz's Avatar
Resident Vagabond
Default Re: why are these welders the same price? (Engloid)
Listen to Engloid, he produces the most beautiful welds I've ever seen.
Tegraracer90
Audio / Security / Video
Mar 15, 2009 08:25 AM
posHonda
Mar 11, 2009 03:51 PM
Torridcivic
23
Aug 1, 2003 02:18 PM
97civic123
Feb 5, 2003 07:49 AM
