Are OEM HID's really worth the money?
Old Jan 1, 2002 | 04:22 PM
AllMotorITR's Avatar
New User
Default Are OEM HID's really worth the money?
Well, I am stuck... Is it really worth the $1200 +/- for the OEM HIDs? Or should I just get an aftermarket HID kit like Philips? I would like to get the most out of it.. Will I notice that much of a difference? I am sick of the Hyperwhite bulbs I have now.
Old Jan 1, 2002 | 04:23 PM
B2FiNiTY's Avatar
Default Re: Are OEM HID's really worth the money? (1 FAST R)
I think Philips is good enough.
Old Jan 1, 2002 | 04:44 PM
New User
Default Re: Are OEM HID's really worth the money? (B2FiNiTY)
You do not think they are worth it? Am I really going to notice that much of a difference b/w a 6000k Philips kit and OEM?
Old Jan 1, 2002 | 04:46 PM
Hybrid ctr's Avatar
according to the HID master Rboosted717
he said it's not really worth it
Old Jan 1, 2002 | 04:55 PM
Turtle's Avatar
Phillips are good for the money and there have been a couple of groups buys for them on honda-tech...just look for some deals and get your friends in on a group buy...
Old Jan 1, 2002 | 04:57 PM
tr4il's Avatar
http://secure15.dellhost.com/~d30022975/hid_philips.htm
i dont know if its worth it...is sure is a lot of $$$ for some lights...
[Modified by tr4il, 8:57 PM 1/1/2002]
Old Jan 1, 2002 | 05:15 PM
Comtechgsr2000s's Avatar
New User
Default Re: Are OEM HID's really worth the money? (tr4il)
Anyone know where I can get HIDs for around $500
Old Jan 1, 2002 | 05:23 PM
Mike M's Avatar
Founding Member
Default Re: Are OEM HID's really worth the money? (Mugenblkgsr2000)
Give us a call tommorow
Old Jan 1, 2002 | 09:53 PM
GsrSenal's Avatar
I just purchased a used set of HIDs from a crashed Acura TL. I only paid $350. They were not a direct fit but I used a little of epoxy to hold the bulbs in and tapped the positive and negative wires into the headlight harness and WHAT A DIFFERENCE! Its pretty much a simple installation if you have some mechanical skill. It is a night and day difference. The road is illuminated 100 times better. I was planning on purchasing a $1200 set or an aftermarket set like Phillips but I prefer using an OEM system(luxury car system like Benz, Bmw's, Audi etc) which was cheaper and they worked perfectly fine. I purchased the set HT member Jracer1, who works for a junker.
[Modified by GsrSenal, 6:55 AM 1/2/2002]
Old Jan 1, 2002 | 10:04 PM
GsrSenal's Avatar
Default Re: Are OEM HID's really worth the money? (GsrSenal)
Here is the ad:
High Intensity Discharge Lighting System (HIDs)
20,000 Volts stronger than regular lights,
Same as the ones used on Mercedes Benz, BMW's
Acura TL's and CL's, Lexus, and etc,
Includes 2 Ballast, 2 Ingitors, 2 Bulbs,
Bulbs will last the lifetime of your car.
No Bulb replacing needed,
Installation is a quick and easy,
With a little a custom fabrication you can have the same
lights as luxury cars.
Shipping at buyers expense,
Picture Available
Jracer1@hotmail.com
$350 Firm
Old Jan 1, 2002 | 11:14 PM
VTEC SPORTS's Avatar
are u having JDM front end? if yes, u should get the OEM hid. it looks lots better than those stupid conversion hid. Conversion is conversion. Don't waste ur money on the conversion kit. Get the real factory hid kit plz. the lens are totally making a big different. and use Japanese Philps or Bellof D2S replacement bulbs to get the BEST result. it worth the money.
Old Jan 1, 2002 | 11:30 PM
New User
Default Re: Are OEM HID's really worth the money? (VTEC SPORTS)
Yeah but $1200! That's money that can be spent on other things.. I'm sure a Philips kit added on to a Non-Hid front end would be far better than the hyperwhites I'm using now. Do you guys agree?
Old Jan 1, 2002 | 11:42 PM
comptechgsr's Avatar
yes....
or u can jus get some PIAA 5000's or 2000's or wutever
and mount them on ur roof
Old Jan 1, 2002 | 11:56 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Are OEM HID's really worth the money? (comptechgsr)
Just **** the JDM front end....then this whole HID thing won't even be an issue. THEN you can get some cams and no one will even see your front end.
Old Jan 2, 2002 | 05:03 AM
Flux's Avatar
Default Re: Are OEM HID's really worth the money? (Fuzznuts)
the new 6000k bulbs will look much more hid like than the oem hids
Ok, that is funny...
Old Jan 2, 2002 | 05:13 AM
sackdz's Avatar
Default Re: Are OEM HID's really worth the money? (Flux)
Yea fuzznuts is the misinformation king. Then he calls other people newbies
Ross: I agree 100%
Old Jan 2, 2002 | 05:42 AM
Benjamin Tang's Avatar
Default Re: Are OEM HID's really worth the money? (sackdz)
i thought we covered this before?
if we are talking jdm coversion w/hid, then yes it's worth it. my friend has a 96specr conversion with the phillips hid setup and his beam pattern is all wrong (there is no horizontal cutoff) and it's causing him grief with the police. i'm told that the 2nd gen jdm dc2r hid setup is even better...
i used to have a 96specr non-hid with hyperwhites... no comparsion.
[Modified by Benjamin Tang, 6:49 AM 1/2/2002]
Old Jan 7, 2002 | 08:17 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: Are OEM HID's really worth the money? (Benjamin Tang)
How about you guys Telling Me if They are Worth it. OEM Acura High INtesity Discharge lamps From a 2001 CL Type S.
[IMG][/IMG] http://members.aol.com/kenneth536/typeRHID1.jpg
Old Jan 7, 2002 | 08:26 PM
Rboosted717's Avatar
Default Re: Are OEM HID's really worth the money? (NDLess Type R #01-0686)
wow that picture is tainted!!! lol
What are those 100,000k HID's!
But yeah OEM and aftermarket kits are both good. If you want the best, OEM is no compairson to aftermarket HID kits. The main advantage is the OEM projectors and housings that are made especially for HID's. Go test drive a new car like the new 3series BMW, 5series, audi, etc... then go jump in a car with a aftermarket HID kit. You will see a difference I promise.
Trust me, I had normal JDM headlights with a Philips kit, then I got a OEM HID setup and the difference is crazy. Worth $1200, um IMO no cuz I would rather have a Mugen seat under my ***, or some nice engine mod, but I was offered a deal I could pass up for them. If I didn't get that deal would I still go and get OEM's? After seening the difference yeah totally! However I'm weird and I obsess over weird things so
Old Jan 7, 2002 | 08:48 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Don't forget that he also believes (like jond) that all hybriders are theives that should go to hell. Gotta love ignorance.
DAlexsanderC
Mar 17, 2011 06:36 PM
BlUeHoOdCiViC99
Lighting
17
Mar 11, 2008 11:12 AM
Petah
Nov 26, 2002 10:33 PM
FritzInTN
Sep 21, 2002 01:07 AM
Xia0w0ng
Aug 12, 2002 11:05 PM
