Why a catalytic converter instead of a test pipe?
Are you wondering about a "catalytic converter vs a test pipe" or about a "cat back exhaust system vs a test pipe" ??
People would install a test pipe to replace the catalytic converter to have a better exhaust flow, however that is no good for the environment.
A cat. back exhaust system consist of all the exhaust piping, including the muffler, from the cat. converter to the back of the car. You cannot replace the "cat. back" with a test pipe.
Hope this help a little.
Is a huge *** fine worth 1-2 whp
if your already turboed and illegal
if your caught in CA with a testpipe
you could get a fine up to $3000
On an ITR with my header and exhaust we barely saw a 2whp difference. However, if you plan to run the car on the track, especially road course, then I'd recommend the test pipe for only those occasions. Otherwise lets keep the air clean as best we can. You may have a problem with a cat that has been run in the VTEC range for extended periods of time, i.e. speed trials or car guys 150-200 miles weekends numerous times a year. The stock ECU runs very rich in the high rpm range which isn't the best for a cat.
wow that sucks.
wow that sucks.
Anyone make a somewhat inexpensive free flow cat that's a direct bolt on for a Spoon header (same length as JDM 4 to 1) on ITR's? If so, what company, and how much is it?
I've been running a test pipe on mine, and the noise is finally getting to me.....
I rode in a car with no cat, and that thing stank up with fumes. I could absolutely not stand riding in that car. And can you really feel 1-2 whp?
Inexpensive cat = Jeg's 2.5" (about $50)
Direct bolt on = no, but any muffler shop should be able to fit it
I think Dave at SMS sells direct-fit Catco cats, but they're more expensive.
Drinker
