those w/jdm itr 4-1 header....wat catback exhaust?
wat kind of catback exhaust systems are u guyz running w/the jdm itr 4-1 header?
just wanted to get sum ideas wat would fit.
Exhaust that fits depends on the outlet of your cat.
having a 2.5 flange on the header side
and either a 2.5 flange or a 2.25 inch flange
for watever exhaust ur going with.
yea thats it....just to make things simpler i was lookin for the words in my head. wat's exhaust got a 2.5in flange to connect to the carsound cat.
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
The cat back system used on for the header test is available and it's already welded together. 2-1/2" OD 16g polished stainless steel, 22" long resonator and a 4" x 9" resonator with one of those huge 2-1/2" tips to get everyone's attention. FYI, I flare the B pipe inlet to be 2-1/2" to 2-9/16" ID so when you bolt it up to a 2-1/2" cat there isn't any mismatch. This system is sized for use with a JDM type header and 16-3/4" cat or test pipe. It was used for 1 day and has started to turn gold in color. Email me for pictures.
2.5" test pipe and the Kakimoto R 70mm OD catback. The Kakimoto R will give you a true 2.5" ID catback all the way to match up with the header and test pipe. Even the bottleneck areas are still around 2.5" and the rest of the b-pipe is 2.55".
And it is fully stainless steel and cost around the same as other Japanese made catback system.
Dave: Do you plan on selling them pre-welded together by any chance? I heard that you were going to but haven't heard anything else? Also, have you made a header for a b18a before? I might need to get one in april or so...
Dave,
I have custom bent material to build B18A/B 4-2-1 headers for SCCA ITA cars however this tubing is 18g since it would be a race application and I wouldn't recommend it for the street. The design is similar to the GSR header expect the tubing diameters are smaller.
Dave,
The header is certainly not holding my back currently, but mid next year at the latest, I'll be talking to you about getting one.
guezroks
Jun 14, 2008 05:17 PM
tuan...
Apr 1, 2005 06:40 PM
drdavidge
Mar 18, 2003 07:02 PM
