NGK spark plugs and msd ignition
Old Dec 5, 2004 | 02:58 PM
hondaeg8's Avatar
Default NGK spark plugs and msd ignition
i have jdm gsr motor and i'm going to get some new ngk spark plugs. i have the complete msd sci ignition kit.
what gap should i set my spark plugs at? stock gap is .044
Old Dec 6, 2004 | 03:13 PM
PreStaged12s's Avatar
Default Re: NGK spark plugs and msd ignition (hondaeg8)
A bigger spark plug gap means more power but there is a certain point you can gap to before you lose efficiency of the spark, I would just say gap them @ 0.40 and see how it runs, then if you want go bigger gap but for driving on the street you really dont need to worry about gapping bigger to make power, your not going to be able to tell a difference.
Old Dec 8, 2004 | 04:00 PM
hondaeg8's Avatar
Default Re: NGK spark plugs and msd ignition (PreStaged12s)
anyone else?
Old Dec 8, 2004 | 10:04 PM
mtber's Avatar
Buy NGK BKR7E-N-11 and leave them alone :-)
Old Dec 9, 2004 | 01:57 AM
JoeB18R's Avatar
Default Re: (mtber)
you would still need to gap them. Id just go with the stock gap measurment.
Old Dec 9, 2004 | 04:05 PM
hondaeg8's Avatar
Default Re: (mtber)
are the 7e's the stock heat range or one degree colder?
Old Dec 9, 2004 | 04:14 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">are the 7e's the stock heat range or one degree colder?</TD></TR></TABLE>
7 is colder, stock for factory hondas are usually 5-6. I use NGK BKR7E-11s, they are cheap too.
Old Dec 9, 2004 | 06:13 PM
hondaeg8's Avatar
Default Re: (LSVTEC 91 Civic)
so the 7's are one heat range colder....could i use a 55-60 shot of zex on these plugs? would i be okay using these spark plugs?
Old Dec 9, 2004 | 06:14 PM
Banned
The rule is - for every 50HP shot of nitrous, or 8lbs boost, go to one step colder. So yes, 7's would work fine.
Old Dec 9, 2004 | 06:21 PM
hondaeg8's Avatar
thank you
Old Feb 4, 2005 | 04:37 PM
cpforyou's Avatar
NGK BKR7E-11 Spark Plugs
Hard to find for a good price sometimes though. Spark Plugs . com sells them for $2.24 each, but expensive shipping.
kte324
Mar 15, 2010 09:36 AM
digital sol
Mar 31, 2007 03:10 PM
1SlowSi
Oct 12, 2005 01:27 PM
Jcup315
Apr 18, 2005 06:08 PM
Dokta
Jan 23, 2002 05:39 PM
