Engine swap for an 87 accord
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOAB »</TD></TR><TR><TD CLASS="quote">cons would be getting mounts etc...
pros... blingin' B factor
more power
mad tyte vtech y0!!!
motor mounts and other parts for a b-series swap are available through Place Racing, Inc.
i've heard that you woud need to get a hold of some of the fuel lines from a fuel injected 3rd gen (since yours is carb'd), but i've never really looked into it.
more power
to do this swap, you will need mounts, which only the late PRI made, axles, a wiring harness (or rewire the one you have), the fuel return line from an LXi or SEi model accord from 86-89...
if you visit http://www.3geez.com, you will find much more information on b series swaps, along with first-had help from people that have swapped b series engines into 3rd gen accords...
SQ is the SQUAD
Welding / Fabrication
Jan 2, 2008 08:42 PM
BoostdRex
Jul 27, 2005 08:38 AM
