tranny or clutch problem?
Old Dec 5, 2004 | 10:52 AM
eclecticteg21's Avatar
Default tranny or clutch problem?
ok, when my car is running and idling, with the clutch down, it will absolutely not go in any gear. but when the car is shut off, it will go through all the gears without any problem. this is with a 96 teg LS manual tranny. i really need to know what is going on here. thanks in advance.
Old Dec 5, 2004 | 12:52 PM
Echo7847's Avatar
Default Re: tranny or clutch problem? (eclecticteg21)
Clutch problem
Pressure plate, friction disc, etc.
Old Dec 5, 2004 | 02:04 PM
TruPerformance's Avatar
Clutch problem. Replace it and get a lightened flywheel at the same time.
Old Dec 5, 2004 | 02:24 PM
WhiteGSR95's Avatar
probably a clutch problem
Old Dec 5, 2004 | 03:56 PM
Mischief_EG's Avatar
Default Re: (WhiteGSR95)
I agree also...clutch problem
Old Dec 5, 2004 | 06:01 PM
honDA16's Avatar
check your clutch fluid, might be low and not disengaging the clutch... just a guesse but worth a look before dropping the tranny.
Old Dec 5, 2004 | 06:26 PM
92hb's Avatar
Default Re: tranny or clutch problem? (honDA16)
if its cable make shore all linkages are tighten, unless hydralic chek fluid. anything other than that clutch
tez94teg
Oct 10, 2005 05:48 PM
mawkiemarc
Aug 1, 2005 08:41 PM
phatstyles
May 1, 2005 05:54 PM
