crx dx rear disc conversion..
Old Dec 5, 2004 | 10:40 AM
tRex99's Avatar
Default crx dx rear disc conversion..
Well i searched and read up on some DC to EG disc but non on crx/hatches...well since my Si was stolen i still have good parts since it was recovered im going to take the rear brakes off andput them on my DX if i get it...now since i have the Si do i need anything else or just pull the whole assembly off and put it onthe dx? What stuff do i NOT need to waste my time with by pulling off the Si because the DX is the same?
also if i want to use the Si sway bars do i need to use the LCA's off it to use them or do the DX have pre drilled holes for them?
Old Dec 5, 2004 | 11:35 AM
tRex99's Avatar
Default Re: crx dx rear disc conversion.. (tRex99)
bump
Old Dec 5, 2004 | 11:43 AM
crexer's Avatar
just pull the entire trailing arm assembly off the Si and use it on your crx. Use the crx compensator arm and the other arm instead of the Si ones. you will need emergency brake cables from a 90-91 crx si.
crxguy406
Sep 8, 2011 05:48 PM
Gruvent
Dec 2, 2007 07:14 PM
crxfreak1117
Sep 29, 2006 03:27 PM
freud
Dec 17, 2002 07:27 AM
