1996 Accord Automatic Transmisson fluid lines to and from radiator
Any one know which automatic transmission fluid line on 1996 Accord 4 cyl is outlet fluid out of radiator back to Transmission , and which line is inlet from transmission to radiator. I need to know sides at radiator, im installing a Transmission oil Cooler . Use drivers side or passengers side of radiator as location answer. Thanks
Modified by First Honda 1976 at 11:44 PM 12/5/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by First Honda 1976 »</TD></TR><TR><TD CLASS="quote"> i.m installing an Transmission oil Cooler . Use drivers side passengers side as answer. Thanks </TD></TR></TABLE>
WAH??? where and how u get one?? i Need one my car iS SHOT my tranny died yesterday.
go to bulkpart.com and pick out the Derale import transmission oil cooler or the one that fits your car best. there CHEAP here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by First Honda 1976 »</TD></TR><TR><TD CLASS="quote">go to bulkpart.com and pick out the Derale import transmission oil cooler or the one that fits your car best. there CHEAP here.
Great site except not very friendly for budding DIY's. Is there any way you can suggest which cooling kit should be usd for 98 4cyl auto 2.3l accord.
Thansk for telling us about the site.
</TD></TR></TABLE>Great site except not very friendly for budding DIY's. Is there any way you can suggest which cooling kit should be usd for 98 4cyl auto 2.3l accord.
There are a few different types of Auto Trans COOLERS , tube and fin , these are the least expensive , then there is Stacked plate , more heavy duty than first. and then there is Finned mostly for racing applications . A cool Tranny is a happy tranny. Do a search online under AUTOMATIC TRANSMISSION OIL COOLER , thers alot of info or go onto ebay.com under same and see the different types good luck.
easiest way to determine which tranny fluid hose is the return line is to start up the car from a cold start. let it run for about 3 minutes and feel the two hoses. the warm one is the one flowing TO the radiator while the cooler one is the return hose. cut the cool hose and use the extra hose to loop through the tranny cooler. its a piece of cake.
