which axle goes in which side???
Old Dec 4, 2004 | 11:21 PM
bboylito's Avatar
Default which axle goes in which side???
hey i am installing a motor into my car and i recieved two axles that are pretty much the same length,
if looking at the car with hood in front of you passenger= left, driver =right side
i was wondeing how do i know which axle goes into the drivers side of the tranny, and which axle goes on the passenger side???
does it matter or can axles just me mixed and matched???
Old Dec 4, 2004 | 11:26 PM
nighttrain33's Avatar
Default Re: which axle goes in which side??? (bboylito)
Lucky you, I just pulled the tranny out of my car and have the axles sitting right in front of me (well, actually they are in the garage). They are both the same length, but by passenger-side axle has a serated ring on the outside part of it, but I don't know if this is because it is not OEM. Other than that I don't know because I couldn't get the intermediate shaft apart from the drivers-side axle. Good luck.
-Shane
Old Dec 5, 2004 | 04:38 AM
DumpedSi's Avatar
Default Re: which axle goes in which side??? (nighttrain33)
what motor..?
The driver side is longer if its sohc and if its dohc the driver side is still longer but its in 2 parts which should be obvious since it wouldnt work any other way.. Think about it the tranny is on the passenger side of the car, so of course the driver side its gonna be longer
Old Dec 5, 2004 | 07:21 AM
bboylito's Avatar
Default Re: which axle goes in which side??? (Slammed Si)
for a b16a2, one axle is slightlt longer i guess its the drivers side ?
Old Dec 5, 2004 | 07:46 AM
slambedcivic's Avatar
just make sure that the axle with the lock ring is on the passenger side.
redman223
Sep 7, 2011 12:15 PM
1BADEGDC2
Transmission & Drivetrain
10
Oct 6, 2009 02:40 PM
stockb18c
12
Apr 6, 2009 01:51 PM
jwbnavy
Dec 9, 2007 12:38 PM
marc.ejay-twenty
Oct 7, 2003 08:54 PM
