preloading coilovers....
Old Dec 4, 2004 | 10:45 PM
ATS*Mark's Avatar
OG triple OG
Default preloading coilovers....
what does corner weighing represent , do you want to preload so weight is evenly distributed? is it a weight transfer thing or a ride quality thing? im tring to undertand preloading more if anyone can break it down for me that would be awsome!
Old Dec 5, 2004 | 04:18 AM
.RJ's Avatar
.RJ
Default Re: preloading coilovers.... (Hella_JDM)
http://www.google.com/search?h...hting
http://www.google.com/search?h...eload
seriously......
Old Dec 26, 2004 | 03:13 PM
PIC Performance's Avatar
Default Re: preloading coilovers.... (.RJ)
Took me quite some time to figure out preloading by reading Google searches, although it did help.
Maybe if you know something about them, you could give a quick and dirty rundown of it.
Old Dec 26, 2004 | 03:29 PM
Patch's Avatar
Default Re: preloading coilovers.... (Noob4life)
Corner weighting doesn't have much to do with preload.
I'm wondering how you can have 10k posts and not understand basic suspension theory.
Old Dec 26, 2004 | 04:38 PM
JDMish's Avatar
Default Re: preloading coilovers.... (Patch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">Corner weighting doesn't have much to do with preload.
I'm wondering how you can have 10k posts and not understand basic suspension theory.</TD></TR></TABLE>
maybe he isn't really into his suspension 'til now. I would also like to know the same thing he does.
Old Dec 27, 2004 | 09:18 AM
Depending on what type of coilovers you use, preloading and cornerweighting can be related.
On coilovers that do not have independent height and preload adjustments, adjusting the preload will also affect ride height. Ideally, you adjust the spring perches on your coilovers to increase or decrease the weight for the specific corner you're working on. However, without individual height and preload adjustment, then you won't be able to do one without changing the other. Its tremendously difficult to cornerweight a car with this type of height/preload adjustment. So, you end up messing up your preload in the process of cornerweighting.
Anyhow, I'll respond to the first poster as best I can: the purpose of cornerweighting is to provide even weight distribution through corners, like you said. Its not necessarily having the same weight at the two front wheels, and the same weight at the two rear wheels, because obviously "unadjustable" weight of the car (the stuff between your four wheels) isn't going to be equally distributed. In any case, you do various calculations to get to your four ideal corner weights, and achieve those by properly adjusting your coilovers. Like I said though, you can't do so without messing up your preload settings unless you have a set of coilovers without independent height and preload adjustments.
I did my best to cover preloading in another post, but the basic idea behind preloading is to allow your coilovers springs to perform at a stiffer spring rate, eg. 600lb springs instead of 450lb. Its done by compressing the springs before they are installed onto the car (hence pre loading them). Then, when they are put onto the car, it takes more initial force to compress the springs, and they will expand with more force as well, just like stiffer springs would.
vyxx-ct
Honda Civic (2001 - 2005)
Nov 29, 2006 08:08 PM
yesSiReK
Nov 13, 2006 02:39 PM
xmr. robotox
Suspension & Brakes
11
Mar 7, 2005 11:17 AM
RACEPAK
Suspension & Brakes
11
Feb 9, 2005 08:56 PM
Greenery18
Suspension & Brakes
22
Jan 25, 2005 05:41 PM
