fuel pump install 90' crx
Old Dec 4, 2004 | 09:43 PM
crxb20ed's Avatar
Default fuel pump install 90' crx
sup guys
has anyone done a fuel pump on a crx? know the tank needs to be dropped.. can I get away w/ doing it on the ground? and does it need to be dropped completely? or just keep a jack under it and drop it enough to get to it? any tips would be helpfull. thaanks!
Old Dec 4, 2004 | 09:53 PM
Redline130's Avatar
Default Re: fuel pump install 90' crx (crxb20ed)
Yeah, unfortunately you need to drop the tank as much as you can. It will be easier that way. You should put the car on some sturdy jackstands, you won't be able to work under your car any other way. You should either run the tank as empty as you can and then drain the remaining gas out. The lighter the tank is, the easier it will be for you. Good luck. BTW, what is your purpose for accessing the pump? Replacement?
Old Dec 4, 2004 | 10:03 PM
civickiller's Avatar
Default Re: fuel pump install 90' crx (Redline130)
yup i replaced the fuel pump on my car, i had the rear up on jack stands, made it way easier. had a flat piece of wood on top of my jack so it sort of help balance it out. but my tank wasnt empty, it was still half full. watch the fuel lines when you take them off. mine was rusted and ended up ripping the fuel line. had to take off everything around the dash, it wasnt fun.
Old Dec 4, 2004 | 10:05 PM
Redline130's Avatar
Default Re: fuel pump install 90' crx (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">yup i replaced the fuel pump on my car, i had the rear up on jack stands, made it way easier. had a flat piece of wood on top of my jack so it sort of help balance it out. but my tank wasnt empty, it was still half full. watch the fuel lines when you take them off. mine was rusted and ended up ripping the fuel line. had to take off everything around the dash, it wasnt fun.</TD></TR></TABLE>
I remember that ordeal you went through LOL!
Old Dec 5, 2004 | 10:49 AM
crxb20ed's Avatar
sup guys,, yeah just upgrading it w/ a 255lph..
Old Dec 5, 2004 | 04:11 PM
crxb20ed's Avatar
ok done.. pretty simple... did not like how the supplied fuel pump rubber groumet fitted though,. also didnt like how the screen is much smaller than the original.. seems you need to make sure the new screens sits as low as the orignal or you'll run outta gas too soon..............w/ gas still registering... thanks guys
hmonkey86
Feb 7, 2012 05:02 AM
lxiaccord
24
Jun 1, 2009 11:43 AM
puertoricanboy90
Dec 26, 2008 03:41 PM
crxricer66
Oct 5, 2007 11:00 PM
trooper0641
Jul 13, 2005 08:21 PM
