crvtec not making any power after vtec??
Old Dec 4, 2004 | 08:21 PM
hybridpatient95's Avatar
Default crvtec not making any power after vtec??
my friends crvtec was working good this morning when the exhaust was on totally. then when a straight away, then the exhaust fell off just from ripping it. on the way home the car would run good except it would be too loud. at like 7grand the car starts dieing like the power isnt climbing, usually it doesnt do this. could it be that the exhaust is to free flow and instead of making power it loses power??? could it be the lack of backpressure?? or something else?? can i get some suggestions??? please thanks!!
Old Dec 4, 2004 | 08:36 PM
jaydmcrx's Avatar
Default Re: crvtec not making any power after vtec?? (kinkbmx159)
Exhaust would have absolutely nothing to do with it. Sounds like your car needs a good once over. Wiring. EXHAUST!!!!! And a bunch of other stuff. When it runs good, and then just all of the sudden goes bad usually meens like a loose connection of some sort. Does vtec work?
Old Dec 4, 2004 | 09:12 PM
Tbone's Avatar
If your cam gears jump timming if will feel similar to what youve explained.. That of course isnt likley though
Old Dec 4, 2004 | 09:27 PM
Default Re: crvtec not making any power after vtec?? (Tbone)
yea vtec works like a charm. there is no problem with wiring it just came out of no where when the exhaust fell off it just lost top end
Old Dec 4, 2004 | 09:29 PM
hOndafienD 04's Avatar
lost a lot of top end....it lost to a single cam...STOCK!...damn that race sucked
Old Dec 5, 2004 | 08:43 AM
Default Re: (hOndafienD 04)
bbbbbbbbbbbbbbbbbbbbhump need answer!
Old Dec 5, 2004 | 01:04 PM
bump
Old Dec 5, 2004 | 01:21 PM
HONDABROMANDUDE's Avatar
is he doing anything for extra fuel?
Old Dec 5, 2004 | 03:50 PM
Default Re: (HONDABROMANDUDE)
umm fuelpressure is all the way up. chipped p28 for fuel enrichment and a vafc and fuel is riched there too
Old Dec 5, 2004 | 04:16 PM
ISawUL00k's Avatar
Default Re: (kinkbmx159)
does it idle differently..
Old Dec 6, 2004 | 12:13 PM
Default Re: (ISawUL00k)
no it runs good
Old Dec 6, 2004 | 01:03 PM
oooooooooooooooooooop
Old Dec 6, 2004 | 01:42 PM
jaydmcrx's Avatar
Have you checked the timing?
Old Dec 6, 2004 | 01:46 PM
dist is all the way advanced....car was running fine since september on this setup till the day that the loss of power started.
Old Dec 7, 2004 | 06:18 PM
ISawUL00k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">dist is all the way advanced....car was running fine since september on this setup till the day that the loss of power started.</TD></TR></TABLE>
advanced all the way?
u have vafc ? what r u using to engage vtec ?
Old Dec 7, 2004 | 07:25 PM
we are running vafc which was tuned before the c-t-r cams and dc 4-1 headers and yes dist is advanced all the way, thats where the car performs best at.....no pinging...so i think we are good to go.
Old Dec 7, 2004 | 08:51 PM
bluebird's Avatar
Check the module inside dizzy!!!
Old Dec 8, 2004 | 02:06 PM
Default Re: (bluebird)
iight g
Old Dec 9, 2004 | 07:08 PM
ISawUL00k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">we are running vafc which was tuned before the c-t-r cams and dc 4-1 headers and yes dist is advanced all the way, thats where the car performs best at.....no pinging...so i think we are good to go.</TD></TR></TABLE>
if ur motor isnt tuned for those cams it or it will act up or ping because ur ***** not tuned
u need to time ur car. if it pings its ur gas not ur timing.
timing will make ur car slow...id double check that.
sounds like ur belt or cam gears slipped maybe ur ditributer sliped
Old Dec 9, 2004 | 07:12 PM
it doesnt ping....i've stated that before, and we are getting the car tuned asap....its been good ever since that day....hope it doesnt start acting up anymore.
Old Dec 9, 2004 | 07:13 PM
ISawUL00k's Avatar
oh.
well good luck.. hope u fix it.
Old Dec 9, 2004 | 07:19 PM
yup....me too...thanx
wrice4
Honda S2000
38
May 21, 2007 01:57 PM
mrdeadman
Jul 17, 2005 10:57 AM
CW_97_ITR
Jun 5, 2003 05:33 PM
