To change the water pump.....
To remove the water pump on an H22A4, the Helms manual says you need to remove the cam gears and then remove the black plastic cover behind the gears / above the water pump.
I don't remember doing this on my other H23, I just unbolted the water pump and bolted on a new one. What's different that makes taking the cam gears off etc. required on the H22?
GSaura
15
Jun 10, 2006 05:18 PM
