HELP! 5th gen accord w/ 01' h22a4 swap NO VTEC!!!
Old Dec 4, 2004 | 04:06 PM
jbonehead85's Avatar
Default HELP! 5th gen accord w/ 01' h22a4 swap NO VTEC!!!
I have a 97 accord w/ an 01' h22a4 swap. There is no vtec. I was told that i may need an OBD1 prelude distributor, or an OBD2A P13 ecu. Engine is throwing codes of crankshaft position sensor, and camshaft position sensor (No signal). Any one know about this? Or have the same prob?
Old Dec 4, 2004 | 05:07 PM
sinister2c's Avatar
Default Re: HELP! 5th gen accord w/ 01' h22a4 swap NO VTEC!!! (jbonehead85)
you can use the obd2 dist if you rewire it for your harness...the crank position sensor is relocated on obd2 engines down by the crank pully
Old Dec 5, 2004 | 11:08 AM
Default Re: HELP! 5th gen accord w/ 01' h22a4 swap NO VTEC!!! (sinister2c)
ok but i was told that i need the obd1 distributor b/c it would be able to read the crank and cam position sensors from the distributor. Another question i have is do obd1 distributors come w/ and internal coil or external? i know the jdm ones come w/ an internal but those arent compatible w/ a usdm engine.
Old Dec 5, 2004 | 03:25 PM
sinister2c's Avatar
all you have to do is run the wire from the crank position sensor it wire it by the dist. USDM are external. JDM are internal. They all work just depends on the wiring. Just rewire to your engine harness.
Old Dec 5, 2004 | 04:26 PM
H2290's Avatar
What ECU do you have now? You MUST have the ECU that accompanies that engine which is the OBDII P13 ECU. Go to the Hybrid section, they should be able to help.
Old Dec 5, 2004 | 04:35 PM
Default Re: HELP! 5th gen accord w/ 01' h22a4 swap NO VTEC!!! (H2290)
Im using a p28 w/ hondata. It was tuned for the engine im using when it was in the car of the guy i bought it from.
Old Dec 5, 2004 | 06:05 PM
H2290's Avatar
Okay, that ECU is fine. Have you checked all wiring by making sure the sensors are getting voltage when the car is on?
Old Dec 8, 2004 | 07:01 AM
yeah vtec is wired fine, everything else seems to be ok but the car is a mutt. Im using an 01' h22a4 w/ a 97accord dist. and an obd1 p28. I think i know what i need but no one can give me a def answer on whether or not the obd1 dist will be able to determine camshaft pos. and crankshaft pos. since the obd1 ecu cant read those 2 sensors in the obd2 engine vtec wont kick in. (thats what im told). Idk much about this **** so im hoping someone can help. Thanks
Old Dec 8, 2004 | 04:01 PM
Eddiebx's Avatar
you need urself an obd1 h22 distributor, all the sensors are in the dist. where as the obd2 one is not
Phvntxm94
Aug 29, 2017 06:13 AM
downNoutCD5
Feb 22, 2013 03:17 PM
sadam-insane
Apr 2, 2010 03:03 PM
civicEXtreme
Jun 14, 2006 03:17 PM
therealnapster
Aug 24, 2001 06:47 PM
