b18c5 overheating
Old Dec 4, 2004 | 03:38 PM
5genhatch's Avatar
Default b18c5 overheating
i have a 92 civic hb with jdm b18c itr motor. when i drive around town the temp on the cluster goes straight to H. i feel the radiator hoses and the upper one is hot as fu@&. and the lower hose is cold. while the car is idiling i turn the heater on and it puts out no heat at all. changed the thermostat and it made no difference. wonder if my water pump or radiator is bad??? anybody have any ideas.
thanks
Old Dec 4, 2004 | 03:42 PM
mmuller's Avatar
Mad Scientist
Default Re: b18c5 overheating (5genhatch)
and you drive around like that?
change your thermostat
Old Dec 4, 2004 | 04:17 PM
5genhatch's Avatar
Default Re: b18c5 overheating (mmuller)
i just changed it today and it made no difference
i was thinking about running it with no thermostat to see what happens. or would that do damage??
Old Dec 4, 2004 | 08:15 PM
HoOridin's Avatar
u got air in ur system.... let the car idle while the the radiator cap is off, and full blast the heater and let all the water circulate until the termostate opens and the fan has come on...them u can refil if nessesary and close the cap
Old Dec 4, 2004 | 08:38 PM
5genhatch's Avatar
Default Re: b18c5 overheating (HoOridin)
i let the car idle today for about an hour. the heater was on flull blast and it was still blowing cold. the upper hose was hot and the lower hose was cold.
dont know what to do???
Old Dec 4, 2004 | 09:16 PM
SiR Inspired ED7's Avatar
if ur car is heating up try not to drive it around
u turn on the car in the morning and u drive around, after how many minutes does ur car start to heat up?
Old Dec 5, 2004 | 08:15 AM
5genhatch's Avatar
Default Re: b18c5 overheating (92 DA B16a)
not even 5min
Old Dec 5, 2004 | 11:43 AM
HoOridin's Avatar
disconnect a lilttle coolent hose in the rear of the engine and pour coolent in there.... try that and then do what i said before about letting it idle...
Old Dec 5, 2004 | 02:22 PM
beaterdriver's Avatar
do u have the stock radiator? if u do, u need a better one, liek the del sol vtec, or integra, or fluidyne
Old Dec 5, 2004 | 08:19 PM
ALF's Avatar
ALF
Here's another thread that deals with overheating. He seemed to have the same problem as you:
https://honda-tech.com/zerothread?id=1064025
Hope that helps.
Old Dec 8, 2004 | 03:48 PM
5genhatch's Avatar
Default Re: b18c5 overheating (ALF)
figured it out, bad radiator. bought a new civic radiator and used hoses from a 94 del sol vtec. now the temp never goes past 1/2 on the guage. thanks for all your help
cookiemonsta08
Jun 2, 2011 08:09 AM
4doorpowa
Jan 24, 2011 12:50 PM
stevenDAtegra
Jul 23, 2009 12:32 PM
Ecugrad
Feb 2, 2005 02:50 PM
cool
Dec 31, 2003 07:26 PM
