damn it, still bogging...
Old Jan 1, 2002 | 12:26 PM
Flamenco-T's Avatar
Default damn it, still bogging...
my car still boged at vacuum, it seems like if I am running at around 45mph, 4th gear, at 3000-3500 rpm, it would bog. I was only steadily/lightly holding the throttle...vacuum is usually at 12mmHG, and I can either depress the throttle a little bit more, the vaccum would rise up to almost 0 and then it would run normal....
or I just let off the throttle....and it would be normal...
I can usually tolerate it, I have been tolerating it for sometimes now....
is it the FMU ? I am running 12:1 with stock injectors and airtex inline...
Art told me about the TOO on drilling the stock FPR to relief some fuel pressure, will this help ?
anyway, I am gonna see if I can swap out FMU and see if it persist again..
TIA
stan
Old Jan 1, 2002 | 12:28 PM
falcongsr's Avatar
What is this crap?
Default Re: damn it, still bogging... (Flamenco-T)
you should not drill out the fpr with stock injectors. do u have an in car fuel pressure gauge? your Vortech FMU may be sticking when you fall into vacuum...
[Modified by falconGSR, 3:29 PM 1/1/2002]
Old Jan 1, 2002 | 12:36 PM
Flamenco-T's Avatar
Default Re: damn it, still bogging... (falconGSR)
thanks Joe, that's what I was thinking, this is the second FMU I have in the car, the first one sticks at idle, I was getting a misfires code left and right at idle...
stan
Old Jan 1, 2002 | 12:47 PM
Arturbo's Avatar
Better than steak
25 Year Member
Dont you just love the FMU?
Old Jan 1, 2002 | 12:59 PM
Flamenco-T's Avatar
Default Re: damn it, still bogging... (Arturbo)
no kidding...the only reason I am tolereating it, is becausa hondata is just around the corner....
crxhybrid85
Oct 14, 2006 07:13 PM
taejin11
Jun 20, 2004 09:45 PM
OneScarySOHC
Jun 9, 2002 01:21 PM
uneekcrx
Apr 26, 2002 08:16 AM
