Ball joints?
Old Dec 4, 2004 | 02:30 PM
sleepin91teg's Avatar
Default Ball joints?
Buying a 89 civic si hatch back tomorow...its all good, but needs ball joints...hes not sure if its upper or lower...how can i tell wich ones are bad? and how hard are they to replace? I also have a 91 integra, i hear i can take the knuckles and swap them over...would the ball joints be part of the knuckle swap? and would it be easier to swap the knuckles, verses replacing the ball joints?!
Old Dec 4, 2004 | 02:34 PM
crxgator's Avatar
Default Re: Ball joints? (sleepin91teg)
lower balljoints are part or the knuckle swap...for upper balljoints you need the whole upper control arm, around 50 a side on ebay or 100 a side from honda...ill be doing that soon...lower balljoints are on the knuckle and pretty easy to take off, you need a pair of snap ring pliers and a BFH...
Old Dec 4, 2004 | 02:51 PM
Default Re: Ball joints? (crxgator)
So is the lower ball joint replacement process easy? i dont know?
Old Dec 4, 2004 | 02:54 PM
Can i do it without a vice?
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepin91teg &raquo;</TD></TR><TR><TD CLASS="quote">So is the lower ball joint replacement process easy? i dont know?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote"> ...lower balljoints are on the knuckle and pretty easy to take off, you need a pair of snap ring pliers and a BFH... </TD></TR></TABLE>
bfh= Big ****** hammer
Old Dec 4, 2004 | 02:59 PM
Default Re: Ball joints? (HatchBox)
Take a long time do to? can it be done alone, or do i need another set of hands? whats tools, other than bfh and snap ring pliers?
driftam1
10
Jul 28, 2008 07:05 AM
90CivicDaily
Jun 4, 2008 04:39 PM
jwbnavy
12
Nov 28, 2007 06:36 AM
MyDragCar
Dec 2, 2004 09:58 PM
