Vtec looses power.
Old Dec 4, 2004 | 01:34 PM
WayFastWhitie's Avatar
Default Vtec looses power.
b18c. GSR block, CTR head. B17 cams, 1st gen b16 IM and TB.
Obd1, chipped P28 stock ITR maps.
It pulls well up to vtec, hits vtec and it just dies, you can hear the imediate change in exhaust note, but the car stops pulling as hard and it really sucks.
No codes, good oil pressure etc. Vtec IS kicking in, it just looses power, it shouldnt do this.
Could it be my cams restricting it perhaps? along with my IM and TB setup?
Thanks any sugestions apreshated
Old Dec 4, 2004 | 02:46 PM
myhatchrips's Avatar
Default Re: Vtec looses power. (WayFastWhitie)
those stock cams need to be swapped for some buddy club spec 3+ cams. tune it and you're all set. good luck
Old Dec 4, 2004 | 03:04 PM
b20todaej6's Avatar
Default Re: Vtec looses power. (myhatchrips)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips &raquo;</TD></TR><TR><TD CLASS="quote">those stock cams need to be swapped for some buddy club spec 3+ cams. tune it and you're all set. good luck </TD></TR></TABLE>
that was the worst answer ive ever heard, theres nothing wrong with your cams, it could be tuning though, probably something wrong with your engine though . . . . . its definately not the throttle body or intake mani . . . . good luck fixing that
Old Dec 4, 2004 | 03:32 PM
Default Re: Vtec looses power. (b20todaej6)
I dont think its mechanical..
Engine is rebuilt with all OEM 30,000KM to date. 210 Compression across board, I had the oil pan off 3k ago and it looked very good. Valve adjustment, Oil changes every 3k. Starts first crank when cold in freezing weather, never jerks or stalls etc. Engine runs extemely well.
Valve timing is 0'0 on cam gears, Igntion timing is 16deg TPS is at 4.5V at WOT. Fuel pressure 42psi.
I thought it might have been the cams and or Intake mani/tb. Since they are far less then what is stock in this setup, maybe restricting the airflow needed for vtec? I really dont know.
Im starting to think it could be the tune, anything i should check, or reasons before changine the tune?
Its not just me, it hits about 6.5k and exhaust note changes and it feels like i let off the gas half way, it keeps reving but dosent pull as hard before vtec. I thought vtec should pull just as hard before or harder, not less. There is a problem.
Any other sugestions? I was thinking about CTR cams, a Abes IM and a ITR/GSR ported TB for future mods.
Old Dec 5, 2004 | 06:09 PM
anything else it could be other then listed above and a bad ecu/program?
Old Dec 5, 2004 | 09:03 PM
mtber's Avatar
Where is your vtec activation point ?
Your fuel pressure should be at 48-52 psi at WOT.
Old Dec 6, 2004 | 07:58 AM
Default Re: (mtber)
i dont have a indash fuel pressure gauge. At idle with the vac on its 42psi. Is this too low?
Vtec is 5800rpm.
Old Dec 6, 2004 | 08:25 AM
drdisco69's Avatar
Default Re: (WayFastWhitie)
Your fuel pressure is good, and the vtec point is fine. It's not mechanical, if you can try a different ecu it would't hurt.
Old Dec 6, 2004 | 01:15 PM
Default Re: (drdisco69)
thanks.
My chips should be here soon, i will burn a new program. If it still occurs i will chip another P28, and even it its something else. I will sell the chipped p28 people are paying crazy money for these things.
Old Dec 12, 2004 | 11:25 AM
problem solved
BAD CHIP No names on who it was chipped by, could happen to anyone.
Re-chipped it myself with uberdata now it runs much better and pulls to redline
1sikhatch
May 13, 2007 04:37 PM
Kjoram
Mar 23, 2007 09:37 AM
pimpnpink
Jan 12, 2007 06:49 AM
jdmfranky
Oct 21, 2006 11:30 AM
bpowa
35
Oct 18, 2004 09:43 PM
