Quick Question about 5 lug
i have a 00 ls, if i coverted to 5 lug itr brakes, and i wanted omni suspension, do i get the dc/eg kit, or the itr kit? any info would be appreciated, thanks fellas.
Whether it's 4 or 5 lug doesn't matter at all. What matters is the lower control arms you use. If you use the ITR LCA's, then you will need the ITR coilovers, if you run anything but ITR LCA's, then you will need the non-ITR LCA's.
thanks for the help guys, i'm looking into gettin omni's pretty soon and just wanted to know whats up. is it necessary to buy lcas? or will the front camber kit alone be fine?
