failed emissions- nox levels are too high. How do I lower combustion chamber temps?
I run 12:5 compression. 12 degrees timing. I have a remapped chip from locashracing in phoenix. Im half the limit on hcl and 1/4 the limit on co. I NEED to lower combustion temps. Right now my cam gears are set at 3 degrees advance exhaust, 2 advance intake.
ANY TIPS ARE WELCOME
-sam
-sam
With compression that high you might be kinda stuck. Compression equalls heat.
Anyway, you might try adjusting the gears alittle for more over-lap. This will act as artificial egr.HTH.
U might wanna try to put a big *** fan in the front while running it....it works for me. Disconnect fuel pressure regulator
CO and HC might change but might do some good for the nox
because disconnecting the fpr makes it run rich.
try what i said, retard the exh cam and increase your fuel pressure.
Unsung
Dec 19, 2003 08:52 PM
DIRep972
Jan 16, 2002 07:29 AM
