96 spec ITR brake upgrade?
Old Dec 4, 2004 | 03:42 AM
cloproductions's Avatar
Default 96 spec ITR brake upgrade?
First things first: I have a 95 GS-R with 96 Spec ITR 4 Lug suspsenion, 4x114.3.
My question: How can you upgrade the brakes on this, i.e.: rotors and calipers?
Is it true you can use the Prelude Rotors on there and VTEC calipers?
What kind of brake pads would I have to get?
Lastly, is it recommended to go with X-drilled, slotted, or both on the rotors?
If you could help me on this with some info, it would be much appreciated, thanks
Old Dec 4, 2004 | 04:51 AM
No-Gi's Avatar
Default Re: 96 spec ITR brake upgrade? (cloproductions)
Do a search for the pads. I remember reading a post in the ITR forum saying which pads you need to buy.
Old Dec 4, 2004 | 05:38 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cloproductions &raquo;</TD></TR><TR><TD CLASS="quote">Is it true you can use the Prelude Rotors on there and VTEC calipers?</TD></TR></TABLE>pre-97 preludes had a 4x114 lug pattern as well, but i don't believe there is such thing as a 'VTEC caliper'.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What kind of brake pads would I have to get?</TD></TR></TABLE>i've heard people recommend axxis and hawk pads
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Lastly, is it recommended to go with X-drilled, slotted, or both on the rotors?</TD></TR></TABLE>depends on what you are going to use the car for. if this your daily driver, you won't see much of an improvement with fancy rotors- you'd be better off just getting the brembo 'blanks'. if you're doing some weekend racing/autocrossing you should consider dimpled instead of drilled rotors.
Old Dec 4, 2004 | 08:24 PM
Default Re: 96 spec ITR brake upgrade? (dFreezy)
thanks for the info, but are the rotors for the pre 97 preludes the same size as the ITR 4 lug rotors?
Old Dec 6, 2004 | 01:49 AM
up...i need some info on this
young geezer
Aug 13, 2011 12:30 PM
TWEKCOUPE
Sep 17, 2007 12:37 PM
DAchiko
Sep 11, 2007 08:06 PM
tnd2gen
Jul 17, 2004 07:58 PM
zRd#1
Mar 27, 2004 08:24 PM
