what you think of my setup????
Old Dec 4, 2004 | 12:10 AM
sloboy_joe's Avatar
Default what you think of my setup????
the block is a b18a and i got it buit weeks ago basically it 12to1 compression has Golden Eagle Iron Sleeves, Wiseco pistons 85mm, Eagle connecting rods, Bore & Hone, Hot tank, Deck, Balance and Micro Polish LS Crank shaft
the head is off a 98 gsr modifications are.Degrease/clean cylinder heads, Port and polish, Deshroud valve and chamber area, Polish chamber, 3 angle valve job running skunk2 stage 2 with crower spring Im also have a set of twm individual throttle bodies with 440cc injectors that are going on as for the tunning runing hondatas100 WHAT ARE SOM NUMBERS TO EXPECT
Old Dec 4, 2004 | 12:18 AM
k20GSR's Avatar
Default Re: what you think of my setup???? (sloboy_joe)
dyno it and find out
Old Dec 4, 2004 | 09:16 PM
sloboy_joe's Avatar
Default Re: what you think of my setup???? (k20hatchie)
dont even trip should b a week r so just wating, so when is that k going in
bertsb18hatch
14
Dec 8, 2010 10:35 PM
whitaker_1991
25
Sep 28, 2009 02:38 AM
