rear jacking point?
Old Jan 1, 2002 | 10:05 AM
Nick's Avatar
Default rear jacking point?
I want to remove these 4x4 mudflaps off of my integra. I got the two front ones off easy but the two rear ones i can't access because the tires are in the way. I need to find a rear jacking point so i can take the tires off and remove the back screws.
Old Jan 1, 2002 | 10:11 AM
nugget8000's Avatar
New User
Default Re: rear jacking point? (prajx)
It's the tow hitch loop thing in the middle right under the liscense plate.
Old Jan 1, 2002 | 10:45 AM
OneThirtyEight's Avatar
Default Re: rear jacking point? (nugget8000)
You can also jack it up in that flat area between the suspension, you will know what im talking about if you look under there. NOT the gastank
Old Jan 1, 2002 | 11:18 AM
Tweakmeister's Avatar
Default Re: rear jacking point? (97blackteg)
Use the tow loop/hook thing. 97blackteg, is that flat area reinforced enough?
Old Jan 1, 2002 | 12:19 PM
GSR2001's Avatar
I removed the rear ones without removing the tires, I just used a small(stuby) screwdriver.
Old Jan 1, 2002 | 12:54 PM
B2FiNiTY's Avatar
I removed mine by using a small screwdriver also. If your going to jack it up, use the rear tow hook.
Old Jan 1, 2002 | 09:56 PM
threatcon13's Avatar
New User
LoL ..the gastank ..LoL!
Old Jan 2, 2002 | 12:20 AM
Default Re: rear jacking point? (KooKaT91)
Why do you guys want to remove those? Cause they get in the way if your car is lowered or something? Or is it just cause they look bad
Both
Old Jan 2, 2002 | 08:18 AM
maggsgsr's Avatar
Yea since I lowered my ****,the mud flaps have been scraping against the ground on bumps,I'm going to sand them down a little and see if it helps because i like the way they look and the protect your body a little from all that crap kickin up.
Old Jan 2, 2002 | 09:09 AM
Nick's Avatar
Default Re: rear jacking point? (maggsgsr)
Yea, i think they look like trash.
By the way i did have a stubby screwdriver but it didn't work. Think i'm just gonna go buy the smallest phillips screwdriver instead of doing all this extra work.
shortlid
Sep 26, 2007 09:33 AM
ED9man
Jul 18, 2006 09:35 AM
Aeka GSR
Feb 28, 2003 06:27 AM
