Fan stays on after car is off.
Old Dec 3, 2004 | 08:37 PM
JDM-EJ1's Avatar
Default Fan stays on after car is off.
My girlfriend has a '90 LX Accord, pushing close to 190k, whenever she turns off the car, the radiator fan (I believe) stays on from 1-10 minutes depending on the length of the trip. I'm thinking it's a bad relay with the fan, any idea on what it could be and what I could do to help her fix it? Car is 100% stock.
Old Dec 3, 2004 | 08:46 PM
fw190bvi's Avatar
Default Re: Fan stays on after car is off. (JDM-EJ1)
its does it for a reason....it will continue to cool the radiator down after the car runs....totally normal
sj993's Avatar
Default Re: Fan stays on after car is off. (fw190bvi)
I think it's normal. Mine does the same thing.
Old Dec 3, 2004 | 08:58 PM
LiL accORd RideR's Avatar
Its normal. It does this on my car too. It keeps your engine cool after it shuts off.
Old Dec 3, 2004 | 08:59 PM
JDM-EJ1's Avatar
Default Re: Fan stays on after car is off. (LiL accORd RideR)
Cool. Thanks for the fast help guys!
Old Dec 3, 2004 | 09:05 PM
ericjackson's Avatar
the only time mine ever did it is when i drove like 130 for about 30 miles. and that was because it ran way too hot. my new accord doesnt ever do it. i think its running to hot, i call a honda service place and ask
Old Dec 3, 2004 | 09:43 PM
91wagon's Avatar
Its normal.
Old Dec 3, 2004 | 10:05 PM
v4lu3s's Avatar
RTFM
event eh sticker from honda under the hood says it is normal!
Old Dec 4, 2004 | 09:25 AM
C_H_A_D's Avatar
Default Re: (v4lu3s)
is there anyway to get my 99 ex fan to stay on for 10 min. My brothers prelude stays on for about 10 min everytime
Old Dec 4, 2004 | 09:41 AM
hondadude's Avatar
No, it is not normal or correct for the fan to run after the ignition switch is turned off. I've only worked on Hondas for over 20 years, what would I know. Ha Ha Ha Ha Ha Ha Ha Ha Ha Ha
Most commonly the thermo switch in line of the top radiator hose is the failed part. Try unplugging it when the fault occurs to see if the fan shuts off.
Oh I almost forgot...Gen, Gen, Gen, Gen, Gen, Gen, thats so much more informative than year and model.
Old Dec 4, 2004 | 10:04 AM
Old Skool's Avatar
IT IS CAUSE HER CAR SUCKS
Old Dec 4, 2004 | 10:06 AM
-RedneckDave-'s Avatar
Working
Default Re: (Old Skool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Old Skool &raquo;</TD></TR><TR><TD CLASS="quote">IT IS CAUSE HER CAR SUCKS</TD></TR></TABLE>
Hmmm. that really contributes a lot.
You should check the antifreeze level and add some cause it sounds like the car is not cooling sufficiently.
Old Dec 4, 2004 | 12:32 PM
v4lu3s's Avatar
RTFM
Default Re: Fan stays on after car is off. (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">No, it is not normal or correct for the fan to run after the ignition switch is turned off. I've only worked on Hondas for over 20 years, what would I know. Ha Ha Ha Ha Ha Ha Ha Ha Ha Ha
Oh I almost forgot...Gen, Gen, Gen, Gen, Gen, Gen, thats so much more informative than year and model. </TD></TR></TABLE>
Please explain the following informatoin given on teh sticker right in front of the radiator in a 4th gen accord:
DANGER
Keep hands away fan may automatically start and run for up to 15 minutes even after the engine is turned off.
If follows in german and french as well. i can take apic if you like
Old Dec 4, 2004 | 12:36 PM
sj993's Avatar
Default Re: Fan stays on after car is off. (v4lu3s)
The retards seem to proliferate this time of year..
Old Dec 4, 2004 | 01:03 PM
StimpyBoy's Avatar
Default Re: Fan stays on after car is off. (sj993)
It is the start of silly season
Just to chime in with everyone else, it's perfectly normal. If it does not turn off after 10 - 15 minutes and leaves your car unstartable then it's an issue.
Old Dec 10, 2004 | 10:26 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Old Skool &raquo;</TD></TR><TR><TD CLASS="quote">IT IS CAUSE HER CAR SUCKS </TD></TR></TABLE>
@ Honda Dude, I forgot to mention I've always been doing the work on my girlfriends car, but I couldn't figure out why the fan would always stay on. After reading these posts I read the stickers underneath the hood, it says it's perfectly normal. Bottom line, you need to find a new job, because your the last stupid **** mechanic I'd take my Honda to get worked on. for posting a stupid comment. for being a shitty mechanic. Die.
@ Old Skool, **** off.
@ everyone else, thanks for all the help guys!!! !
Old Jan 1, 2005 | 07:23 AM
diyer's Avatar
* B A N N E D *
JDM, I agree, that's perfectly normal and what you want your Honda to do when the temp calls for it - if it don't there is a problem. Total incompetence indeed. Scarry.
Old Jan 1, 2005 | 08:12 AM
deechiguy's Avatar
I had the same problem. It went into the shop and I was told that my radiator was going bad. My fan would stay on after the car was shut off. I had the radiator replaced and it never happened again...
Jmullins665
Aug 27, 2017 09:40 AM
STR8V8
Jan 31, 2016 05:12 PM
Tdawg_1993
Jun 30, 2015 04:33 PM
junior91hondaac
Oct 27, 2014 12:03 PM
accord ex
Feb 21, 2003 11:01 AM
