crx with ls swap vs. 95 civic coupe with gsr swap
i was just writing to get your opinion on this battle. he(the crx driver) recently swapped in a b18a1 into his crx with no a/c or power steering. its all stock internally. ive got a 95 civic 2 dr witha b18c all stock as well with the exception of a short ram and an apexi vafc.(vtec set at 4700) i know the crx weighs less, but by how much? im sure the power to weight ratio played a big part because he got me from take off all the way to the end of the quarter. i was creepin on him in third gear, but not quick enough. someone let me know what my problem could be.
Modified by lazyeyez at 11:33 AM 12/3/2004
coupe is a heavy car as if you had a integra. i too have the same set up as your and dissapointed in my 1/4 timeslip. you will need a lot more upgrade to spank that crx due to weight factor.this is just my opinion, unly someone can shed some light into this.
well no i raced my buddy he has a eg with a gsr and i have an si crx(heaviest model 2295) and i beat his *** everytime out of the hole and at 3rd he starts to creep up and at 4th he starts to pass slow...eg hatches are pretty light too..if u guys went from a roll ud beat his *** but non vtec ls owns vtec out of hole! but ims till doing a gsr in my rex wanna race
Well I can tell you one thing that will make your car faster get rid of your VAFC cause unless you have had your car proffesionaly tuned on it you have done nothing but take HP away from yourself. 98% of people sit and play with it change Vtec change this and that and it just makes your car slower. If you are using a factory manifold then you for sure want the dual stage vtec which I beleive if you are using the VAFC then you are by-passing some part of that. Other then that I agree with the other posts he is either a better driver or has a faster car...........................
spangler
May 28, 2002 03:47 AM
nickgomez
20
Dec 30, 2001 02:53 PM
