collector question
Old Dec 3, 2004 | 07:26 AM
anotheredhatch's Avatar
Default collector question
what are you guys using to cut
the angles for collectors,i have chop saw but it doesn't seem to work all that well.
all input is appreciated
thank you
Old Dec 3, 2004 | 07:36 AM
Ekasey's Avatar
Default Re: collector question (anotheredhatch)
Band Saw with 14-16 teeth per inch blade
Old Dec 3, 2004 | 11:25 AM
Karterguy13's Avatar
Default Re: collector question (eLusive ek4)
LOL I was going to ask this question myself yesterday.
How do you achive that angle though. Do you have a bandsaw you close down on the piece or do you have a stand up one? Is there a jig you use to do it? anyn pictures? care to share the angle on a 2-1 collector/
Old Dec 3, 2004 | 12:32 PM
civicross's Avatar
Default Re: collector question (Karterguy13)
You probably wont get a picture from burns
Old Dec 3, 2004 | 12:33 PM
98AccordEX's Avatar
do a search. you'll find plenty to answer your question
Old Dec 3, 2004 | 12:49 PM
Ekasey's Avatar
Default Re: collector question (98AccordEX)
It's a stand up band saw and we have devloped our onw tooling over the years
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross &raquo;</TD></TR><TR><TD CLASS="quote">You probably wont get a picture from burns </TD></TR></TABLE>
you are correct my sincerest apologies
Old Dec 3, 2004 | 01:07 PM
thanks for the info
Old Dec 3, 2004 | 01:54 PM
It's cool I didn't think so. I have it all figured out except how to cut it. GRRRRRRRRRRR
Why does everyone say to search. every time i try I find nothing.
Old Dec 3, 2004 | 03:47 PM
ThaOnlyStunna03's Avatar
search collector in welding fab and whola there you will find you answer or I'll just tell you nobody is gonna show/ tell you how to make one all I know is you use a jig that will cut the same two angles in all 4 pipes
Old Dec 3, 2004 | 04:17 PM
triple_s1x's Avatar
Default Re: (ThaOnlyStunna03)
Yea your really gonna need a bandsaw i personally use a horizontal, and have a jig made up that holds the pipe in place.
Old Dec 3, 2004 | 09:06 PM
94exguy's Avatar
Good trick is to use pvc pipe for figuring out jig, angles and what not. That way your not wasteing good pipe.
.02
Old Dec 4, 2004 | 04:02 AM
jailwarm's Avatar
Default Re: collector question (94exguy)
I have the to scale vectorworks drawing(similar to cad. i dont have CAD so this is what i had to use) on my computer, all you need to do is download the small file and the viewer(19MB free from their site).
This was made for Schedule 40 SS304. You can use Schedule 10 to. The deminsions i was given for the T3 flange were wrong, but i have a flange here and i compared and the cuts still work.
Basically all you need to do is lay the piece of pipe on the piece of paper, make a mark on the places where cuts need to be made. connect the two points with a line, cut along that line at the desired angle with a horizontal bandsaw. To figure the angle, measure the distance from the line on the paper to the outside of the pipe(X). Then figure about how high you want it to go(Y), then type Tan-1(Y/X) whatever angle that comes out to, adjust it on your horizontal bandsaw and line it up, drop the saw, see how things go.
I havent been able to test it on a horizontal bandsaw since i dont have access(BOOO) but i tried it on a verticle one with PVC(yes, the same specs as your SS aka use it for a mockup) and it came out like garbage because it was very difficult to setup a guide system. Horizontal is def. the best way to go.
Anyone interested in the vectorworks file so they can just print it out and use it as their guide here are the links:
http://www.nemetschek.net/down...iewer
http://www.ecimulti.org/uberda...s.zip
BTW: if this works for anyone, i expect a a free collector
Old Dec 4, 2004 | 01:38 PM
Default Re: collector question (jailwarm)
I searched didn't find much
Old Dec 4, 2004 | 01:53 PM
98AccordEX's Avatar
https://honda-tech.com/zerothread?id=1005299
i found that in 3 seconds by using what the guy up top said
another 5 seconds and i found this
https://honda-tech.com/zerothread?id=1005037
and the next thread if you dont wanna make them
https://honda-tech.com/zerothread?id=988824
Old Dec 4, 2004 | 02:55 PM
I said I didn't find much not nothing. None of the poasts I found answerd my questions
Old Dec 4, 2004 | 03:56 PM
98AccordEX's Avatar
the whole first post i listed is about making jigs. like was said above. a lot of people dont share how to make a jig because it takes a lot of time to set it up and get it perfect. buy one of their sets and figure out how to make cuts like they did
Old Dec 4, 2004 | 08:49 PM
Yeah, but I was trying to figure out some angles and stuff. the one jig idea I saw I'm probly going to use. oh well. When I figure it out I'll share to those who want to know. Better yet I'll sell it for $5.00 per person LOL
Old Dec 4, 2004 | 11:48 PM
jailwarm's Avatar
You guys must be tards because i just posted instructions that should REALLY get you started in the right direction. Hell, i even spent the time to make the collector a freaking rectangle vs what everyone else does which makes it a square.
Old Dec 5, 2004 | 01:38 AM
94_HATCH's Avatar
Default Re: (jailwarm)
I got it from your post! Thanks
Old Dec 5, 2004 | 04:12 PM
Default Re: (94_HATCH)
No not a tard. It was great info. Not enough detial for my slow brain. I am also making a 2-1 collector. I have it figured out now I guess. I'll poast pics when I'm done.
Old Dec 5, 2004 | 09:09 PM
granteeton's Avatar
i like that diagram. i opened that thing in mspaint and played with it for about an hour coloring stuff and overlaying it with each other, very entertaining.
Old Dec 19, 2004 | 09:36 AM
Default Re: (granteeton)
I made mine up yesterday. Once they are welded I'll post some pics. I forgott to bring my digital camera to my friends house to shouw you how it's done. They didn't come out quite how i wanted them but they will flow.
Asstastic
May 14, 2010 12:53 AM
silentdaredevil2
Oct 8, 2006 09:07 AM
aw94teg
May 25, 2006 07:24 PM
lv6l
Oct 6, 2005 01:27 AM
danielm3
Welding / Fabrication
19
Oct 4, 2005 12:09 AM
