EF hubs on EK
Old Dec 3, 2004 | 06:17 AM
Turbo88hatch's Avatar
Default EF hubs on EK
Just wondering if the EF front hubs were interchangable with the EK hubs and vice versa? I did a search but came up with nothing...........thanx!
Old Dec 3, 2004 | 07:46 AM
vtecn8ive's Avatar
Default Re: EF hubs on EK (Turbo88hatch)
I believe it will not working messes up camber that a camber kit can't even fix.
Old Dec 3, 2004 | 06:07 PM
XrcR6's Avatar
Default Re: EF hubs on EK (vtecn8ive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">I believe it will not working messes up camber that a camber kit can't even fix.</TD></TR></TABLE>
I believe he might be talking about just the hubs and you're thinking of the whole hub/knuckle assembly.
I'd think it would come down to getting the right wheel bearing... sorry can't offer much more than that.
Old Dec 3, 2004 | 06:19 PM
99hatch's Avatar
arent 14" hubs just 14" hubs??
Old Dec 3, 2004 | 06:34 PM
XrcR6's Avatar
Default Re: EF hubs on EK (99hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hatch &raquo;</TD></TR><TR><TD CLASS="quote">arent 14" hubs just 14" hubs??</TD></TR></TABLE>
I've never heard of a hub being referenced by the wheel diameter. You can put whatever size wheel on a hub as long as the bolt pattern is correct and the center bore clears the hub flange.
A hub is #3 in this pic:
I thought the original poster is asking whether a hub designed for an EK will fit on an ED/EF. The 2nd guy is thinking about swapping the whole knuckle assembly (#6 & 8).
Old Dec 3, 2004 | 06:35 PM
99hatch's Avatar
Default Re: EF hubs on EK (XrcR6)
i was thinkin hub caps my bad...my ricer bro had some spinner ones that he bought by wheel size
Old Dec 3, 2004 | 07:48 PM
vtecn8ive's Avatar
OOps I am the second guy and yeah I thought he was talking about the knuckle assembly. I would assume it would in up but would the rotor sit farther out or more in? If so that would cause the caliper not to fit. But I could be wrong. **** it pull one hub out and put in the other one!! Then everyone will know
wakaranai
Sep 20, 2008 12:02 PM
Tyounin608
Mar 31, 2008 08:19 AM
elf469
35
Mar 6, 2008 03:52 PM
SVOboy
11
Aug 8, 2006 02:17 PM
JDMCRX
May 25, 2003 07:12 PM
