opinion on running a oil/tranny cooler
From: gravity rides everything...everything will fall, se GA/ne FL
converting to 5-speed...i have a big *** tranny cooler mounted and i won't need it for cooling the auto tranny anymore (golly...i sure am going to miss the car shifting all by itself all slipping and **** and hitting the rev limiter). i am probably going to turn it into a oil cooler. do i need to put it between the oil pressure port at back of the block and the turbo feed? the cooler is mounted where the a/c condenser 'was'. will this be something worth taking the time to do and how much will it matter?
