how big are the brakes on the 00' si
Old Dec 31, 2001 | 10:07 PM
-Darren-'s Avatar
Default how big are the brakes on the 00' si
read topic.
Old Dec 31, 2001 | 11:51 PM
owen_the_soyboy's Avatar
Default Re: how big are the brakes on the 00' si (lynnheart)
small.
Old Jan 1, 2002 | 12:22 AM
Mario's Avatar
Default Re: how big are the brakes on the 00' si (owen_the_soyboy)
small.
you beat me to it.
Old Jan 1, 2002 | 01:16 PM
-Darren-'s Avatar
Default Re: how big are the brakes on the 00' si (Supersonic DC2)
how big are the brakes in inches.
Old Jan 1, 2002 | 01:35 PM
EG8R's Avatar
10 at the biggest is my guess. You need 15's like on Rally cars.
Old Jan 1, 2002 | 04:45 PM
sa21199's Avatar
10.3 i think...same as gsr.
Old Jan 1, 2002 | 08:36 PM
Gump's Avatar
Default Re: how big are the brakes on the 00' si (sa21199)
they are 10.7 bigger than the gsr's
Old Jan 1, 2002 | 09:16 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: how big are the brakes on the 00' si (xlr8si)
They are not bigger than GSR's.
GSR, LS/GS/RS, Civic EX (92-2k), Civic Si HB, and Civic SI (99-2k) are all the same size.
Some others too, but don't remember.
If you're not sure, check out http://www.powerslot.com and check the numbers.
I'll bet your SI takes part numbers PSL522 and PSR522, the rear is PSL308 & PSR308.
Old Jan 1, 2002 | 10:49 PM
Gump's Avatar
Default Re: how big are the brakes on the 00' si (B18C-EJ1)
civic si
integra gsr
Old Jan 2, 2002 | 12:22 AM
B18C-EJ1
Guest
Posts: n/a
That must be a misprint. Personally I don't trust anything that SCC prints as hearsay.
When the powerslot website becomes available again, I'm sure you'll find that the GSR and SI are the exact same.
Old Jan 2, 2002 | 02:18 AM
vpc's Avatar
vpc
New User
as far as i'm concerned the front rotors on the si and the gsr are the same. its the calipers that are different.
Old Jan 2, 2002 | 05:48 AM
Trey's Avatar
25 Year Member
Default Re: how big are the brakes on the 00' si (vpc)
They ARE 10.3, same as the GSR. Why would a car that weighs less and has a slower motor have bigger brakes.
SCC sucks!!!
Old Jan 2, 2002 | 07:07 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: how big are the brakes on the 00' si (Trey)
That's why I don't believe everything I read - magazines aren't the best source for good info.
Old Jan 2, 2002 | 07:10 AM
killingtime's Avatar
I put 00 Si (front and rear) brakes into a 92 Hatchback - the fronts are 10.3 and the 00 is bigger than the 92. The rears appeared the same, not sure as the whole assembly swapped. Only the front hub (rotor and caliper) assembly swapped,
Demian
Old Jan 2, 2002 | 08:23 AM
StolenSi's Avatar
Default Re: how big are the brakes on the 00' si (killingtime)
Either way, the calipers are still WAY too small, especially the rears. The car can't stop for ****. People can argue that the sucky stock rubber plays a large role in that, but tires don't stop the car, they are just a factor.
Old Jan 2, 2002 | 08:32 AM
Brian*'s Avatar
Default Re: how big are the brakes on the 00' si (StolenSi)
get better pads, i did, it made a world of difference. stock pads hot are as good as my Carbotech Panther Plus' cold
Brian
cwhiteteg
Apr 27, 2005 11:36 AM
57one
Mar 23, 2003 08:43 PM
