primer paint job cost?
Old Dec 2, 2004 | 09:08 PM
sleepercivic04
Guest
Posts: n/a
Default primer paint job cost?
I was wondering how much will it cost for a primer grey paint job on a 94 integra
Old Dec 2, 2004 | 09:22 PM
WhiteGSR95's Avatar
do it your self, sand paper and primer paint
Old Dec 2, 2004 | 09:23 PM
jjj's Avatar
jjj
Default Re: primer paint job cost? (sleepercivic04)
about 5 cans of paint from pepboys- 10 bucks-
haha
it depends on if your doign the work yourself- and if ur just primering over your paint
Old Dec 2, 2004 | 11:40 PM
Calsonic's Avatar
If your going to spend the money for an entire primer coating then why not just get it painted? Everything is going to get masked off anyway so it would be easy for the paint shop to spray paint & clear coat.
Otherwise if you want to save money, just buy a couple of primer cans from an auto parts store and DIY.
Old Dec 3, 2004 | 12:19 AM
SlipAngleX's Avatar
If you were to primer and sand the car yourself, how much $$$ would you save, instead of having it done by a shop?
(no hijack intended)
Old Dec 3, 2004 | 12:48 AM
Calsonic's Avatar
Default Re: (SlipAngleX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlipAngleX &raquo;</TD></TR><TR><TD CLASS="quote">If you were to primer and sand the car yourself, how much $$$ would you save, instead of having it done by a shop?
(no hijack intended)</TD></TR></TABLE>
You'd save a huge amount of money doing it yourself. It shouldn't cost more than $50 in sand paper, sand block, primer cans (depending on name brand), and masking tape. All it takes is time and labor.
Old Dec 3, 2004 | 01:23 AM
jjj's Avatar
jjj
if your really planning on primering the car- you might wanna consider jsut painting it while your at it- seriously-especially if your goign to do a legitamate job- if you dont really care then go to it with spray paint for a local store- but if you even thinking about paying to primer - you should think about getting it sprayed as well
seriously- when it comes to paint - its all or nothing-if your interested it really depends on the materials used and how extensive in quality you want your paint job to be-
i know u can even rent spray booths or pay for the complete job-if you want a basic primer and spray- with a standard color it could run around 300-400-depending on if you want the door jams painted and so on
Old Dec 3, 2004 | 04:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepercivic04 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering how much will it cost for a primer grey paint job on a 94 integra</TD></TR></TABLE>
I hope you don't plan on leaving it like that. Primer absorbs moisture and will eventually lead to problems if it's not sealed with paint and/or clearcoat.
kixcrx
Paint and Body
18
Aug 31, 2007 04:31 PM
broketuner-Sol_Si
Feb 13, 2006 09:52 PM
VINtegra90
Jul 9, 2005 02:49 PM
TheNasty0ne
Aug 19, 2004 03:02 PM
posterchild
20
May 27, 2004 03:41 PM
