NEED HELP FOR EMMISIONS
Old Dec 2, 2004 | 08:35 PM
JDMBOOGERHATCH's Avatar
Default NEED HELP FOR EMMISIONS
i got a 96 civic hatch wiht a OBD 1 b16a ..... i prepared it for emissions and i am running a 96 GsR ecu , got a type R oil pump and a crank sensor on it .... i am throwing 3 engine codes .... 20 - Electrical load detector , 41 - Primary oxygen sensor heater , 65 - Secondary oxygen heater .... i am running the car on the original CX harness re-wired for obd1 parts ( distributor, alternator etc....) my O2's i had to add like a foot of a wire to make it reach .... i don't know what to do about those codes .... i need help please ... suggestions?
Old Dec 2, 2004 | 08:57 PM
Default Re: NEED HELP FOR EMMISIONS (JDMBOOGERHATCH)
bump
Old Dec 3, 2004 | 06:49 AM
v4lu3s's Avatar
RTFM
well you need to wire in teh other 3 wires for your primary o2 sensor. your cx used a 1 wire o2 sensor, but most hondas now use a 4 wire and have a heated circuit. then you need to wire in your secondary o2 sensor that runs behind the cat to test cat efficiaency. for the ELD you may be SOL i believe the cx may not use an ELD, though if it does it is usually in the fuse box under the hood.
Markb16a
May 13, 2007 08:26 PM
burnitdown
Apr 30, 2007 01:27 PM
MxJones92
Jan 5, 2006 06:16 AM
FaceTuned
Sep 13, 2005 12:57 AM
EG6owner-T
May 16, 2003 11:24 PM
