not enough Engine Oil
Old Dec 31, 2001 | 08:40 PM
d8168055's Avatar
Default not enough Engine Oil
i use Mobil 1 full synthetic, and usally a honda filter or FRAM as a last resort... the manual says to put 4.25 quarts, but i usually just put 4 qts or 4 bottles. is this bad? should i put that extra .25 in?
Old Dec 31, 2001 | 09:09 PM
B2FiNiTY's Avatar
Default Re: not enough Engine Oil (d8168055)
Not bad. Not good. Doesn't matter that much unless your car burns lots of oil.
Old Dec 31, 2001 | 09:19 PM
sgT's Avatar
sgT
This is common sense.
You have a dipstick for a reason. As long as the oil level is where its supposed
to be then you are ok. DOnt worry so much about specs.
Old Dec 31, 2001 | 09:33 PM
Comtechgsr2000s's Avatar
New User
Default Re: not enough Engine Oil (sgT)
You only need 4 quarts becuase the .25 oil is in your engine.
[Modified by Mugenblkgsr2000, 6:33 AM 1/1/2002]
76 camaro car
Mar 4, 2016 12:27 PM
eHMxhACk
Mar 12, 2014 08:45 PM
chuckylee97
Jan 27, 2007 02:14 AM
return_2020
Honda Civic (2001 - 2005)
Sep 2, 2006 06:44 PM
RCautoworks
Dec 31, 2002 10:42 PM
