I NEED HELP… QUICK…
Old Dec 2, 2004 | 06:47 PM
mdj_ge's Avatar
Default I NEED HELP… QUICK…
I just went to my car started it, went into reverse and then it’s stuck… wouldn’t go anywhere even if I force it… is it my Tranny or is it my Clutch??? HELP ME..
Old Dec 2, 2004 | 06:48 PM
Hawkze_2.3's Avatar
Default Re: I NEED HELP… QUICK… (yangja)
Have you tried pumping the clutch pedal?
Old Dec 2, 2004 | 06:50 PM
AndyD's Avatar
Sounds like the issue I had. It turned out to be a bad clutch.
How old is your clitch??
Old Dec 2, 2004 | 07:03 PM
matix's Avatar
Default Re: I NEED HELP… QUICK… (AndyD)
If the pedal doesnt come back up its your clutch clyinder. Had same problem and replaced both master and slave cylinder.
Old Dec 2, 2004 | 07:06 PM
hOndafienD 04's Avatar
could be a lot of stuff...most likely a slave cylinder...does it go into the other gears? try shutting it off and then try switching....make sure you have no coins or somthing stuck somewhere in the shifter.
Old Dec 2, 2004 | 07:19 PM
AndyD's Avatar
Default Re: (hOndafienD 04)
HAHAHA. Guys, drive your car and then try to push it out of gear without using the clutch. It will come right out. There is NO WAY it is his clutch master or slave cylinder.
A bad clutch master or slave cylinder might prevent him from putting the car in gear. It WILL NOT prevent him from taking it out of gear.
The only two things that I think it could be is the clutch or the shift fork. I am willing to bet it is a bad clutch (warped clutch disk).
Old Dec 2, 2004 | 07:30 PM
EKboyEK96's Avatar
im me..
Old Dec 2, 2004 | 07:42 PM
mdj_ge's Avatar
Default Re: (AndyD)
I can still start my car... i was in reverse and i can reverse my car but it wouldn't let me go back into neutral. i kinda forced it into neutral so that i can push my car forward... not it's just stuck in neutral... is it the clutch??? also when i step on the pedal it still comes up...
Old Dec 2, 2004 | 07:45 PM
Hawkze_2.3's Avatar
Default Re: (yangja)
Check the oil level in the tranny. Mine did that once and it was almost empty...
Old Dec 2, 2004 | 07:53 PM
AndyD's Avatar
Sounds like a clutch issue to me. I would first check the tranny oil.
If it's not the tranny oil, I would have to say it is the clutch. How old is your clutch?? Do you drag race a lot??
Old Dec 2, 2004 | 08:04 PM
mdj_ge's Avatar
Default Re: (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a clutch issue to me. I would first check the tranny oil.
If it's not the tranny oil, I would have to say it is the clutch. How old is your clutch?? Do you drag race a lot??</TD></TR></TABLE>
i just did the h22 swap... they told me the engine only has 10k miles when i bought.... but the first week after i swaped it i did take it to the track and red line a few times and also did so race off the side with it too on the streets...
Old Dec 2, 2004 | 08:10 PM
AndyD's Avatar
JDM H22 swap??
You should've seen how bad my JDM H22 clutch was when I got the car. It was so warn down that the clutch disk rivets started gringing into the flywheel.
I assume you did not change the clutch while the motor was out, did you??
Old Dec 2, 2004 | 08:15 PM
Default Re: (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">JDM H22 swap??
guess they really beat the **** out of their cars in japan.
Old Dec 2, 2004 | 08:21 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">
guess they really beat the **** out of their cars in japan. </TD></TR></TABLE>
Yeah. I guess they don't care about the motor if they know they are going to have to change it a few years down the road anyway.
I changed the clutch, oil pump, timing belt, seals, water pump, intake manifold gasket, and a few other things before I swapped the motor in. I didn't want to risk ANYTHING. It's too expensive to skimp, only to find out a clutch or an oil pump is bad and then have to pull the motor out again.
Old Dec 2, 2004 | 08:39 PM
mdj_ge's Avatar
Default Re: (AndyD)
I assume you did not change the clutch while the motor was out, did you??</TD></TR></TABLE>
YEAH, JDM motor swap and yeah, i didn't change the clutch becuase i thought i would be kool since it was just 10k... guess i'll change the clutch tomorrow... thanks guys for all the help....
Old Dec 2, 2004 | 08:40 PM
Sabbotage's Avatar
Default Re: (AndyD)
My clutch in my swap was exactily the same way......i think they threw an old crappy clutch in mine because the tranny was from a different engine.....so im betting your clutch is owned too
Old Dec 3, 2004 | 06:45 AM
simon98h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote">
YEAH, JDM motor swap and yeah, i didn't change the clutch becuase i thought i would be kool since it was just 10k... guess i'll change the clutch tomorrow... thanks guys for all the help.... </TD></TR></TABLE>
Don't forget to re-surface your flywheel as well.
madeinchina
Transmission & Drivetrain
May 16, 2011 12:38 PM
96WhiteOnBlack
Mar 26, 2007 07:15 AM
candy eg
Jan 11, 2006 08:22 AM
johnqt3
Oct 7, 2005 11:05 AM
herbalist
Mar 25, 2005 07:59 PM
