Timing Issue - Timing Belt Off Possibly
Old Dec 2, 2004 | 06:31 PM
dr_latino999's Avatar
Default Timing Issue - Timing Belt Off Possibly
Here is the setup -
D16A6 Head Milled .0030"
Stock Bottom End
Here is the problem -
When setting the ignition timing with timing light, to get the crank pulley's three dashes to line up with the sight in the cover involves moving the ignition timing all the way to 10 degrees. In doing this, the distributor had to be turned as far as possible to the fire wall, which leaves me to believe that the timing is off about....8 degrees or so which just so happens to be the distance that one tooth on the timing belt being off would change it. Am I right in this belief or is there a whole other problem all together?
Old Dec 2, 2004 | 07:07 PM
fourthgenhatchB17's Avatar
Default Re: Timing Issue - Timing Belt Off Possibly (dr_latino999)
Why dont u just pull the TB upper cover off and take a gander.
Old Dec 2, 2004 | 07:09 PM
StorminMatt's Avatar
It probably is off. Take a look at the timing marks and see for yourself, though.
Old Dec 2, 2004 | 07:12 PM
mr. carpenter's Avatar
Default Re: Timing Issue - Timing Belt Off Possibly (fourthgenhatchB17)
you reset the crank to tdc when you did the timing? it is possible it's off a tooth. it would be a pain in the *** but, i would just redo and make sure.
Old Dec 2, 2004 | 07:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Why dont u just pull the TB upper cover off and take a gander.</TD></TR></TABLE>It is off, but I have only done the timing once before - when I put the head on the motor, so there is room for error in my untrained eye. But does 8 degrees sound about right for one tooth?
Old Dec 2, 2004 | 09:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">It is off, but I have only done the timing once before - when I put the head on the motor, so there is room for error in my untrained eye. But does 8 degrees sound about right for one tooth?</TD></TR></TABLE>
Im not sure what one tooth equals. Like someone else stated, put the crank at TDC and look at the cam sprocket marks in relation to where they need to be pointed. Check a manual for the procedure.
dem0nk1d
Jun 27, 2012 12:39 PM
technine
Apr 2, 2009 10:36 AM
lsegcoupe
Dec 22, 2006 07:54 PM
White86CRXSi
Aug 27, 2004 03:19 PM
slowassgsxr750
Jan 11, 2003 10:23 AM
